Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By audri5
  • 1 Post By mklabove
    jordo487's Avatar
    Posts
    Global Posts
    406 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Weather not updating/Calendar reminders
    Anyone else using the homescreen with the weather widget and having problems with it updating? It seems to be updating like every couple days on average.
    I did just notice one thing, it seems that I have to have the GPS on (on my phone) or else the weather refuses to update on my gear.
    Also I have had a few meetings today and haven't seen the reminders come to my gear. Shouldn't they be and anyone else?
  2. #2
    JacksonEdwardHarrison's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Weather not updating/Calendar reminders
    I am assuming you have your weather set to update hourly? If so, reboot your watch?
  3. #3
    mklabove's Avatar
    Posts
    Global Posts
    39 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    FWIW, I'm using the weather clock face, and I'm seeing erratic updating, and I have it set to update every hour. (GPS is on.) This morning, it hadn't updated since last night at 7 pm. Touching the little 'refresh' symbol on the weather screen would start the watch "Loading", but nothing would change. I tried disconnecting, rebooting the watch, opening the Accuweather app on the phone, nothing. The only thing that did work was going into the Weather settings in Gear Manager, and unchecking the 'Use current location' box, and re-enabling it.
    Keith
  4. #4
    audri5's Avatar
    Posts
    Global Posts
    157 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't know if this will help but when I had the same problem on the gear 1 I rebooted both of them at the same time. (Phone and watch) After that is would work fine unless bluetooth disconnected and then I had to start them together again. Hope tnis helps.
    jordo487 likes this.
    jordo487's Avatar
    Posts
    Global Posts
    406 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by audri50 View Post
    I will have to try this, though I do not want to reboot all the time.
  6. #6
    mklabove's Avatar
    Posts
    Global Posts
    39 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    FWIW, ever since I unchecked and re-enabled the location box in the Weather setings (in Gear Manager), my watch has been updating every hour. YMMV.
    1812dave likes this.
  7. #7
    Cherenkov's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Having the same issue here. I even factory data reset both the phone and the watch to try and fix it, no luck. Upset that my pebble watch could display the weather accurately (with a 15 minute refresh) and the Gear 2 cannot. I tried mklabove's fix, and found something interesting: If my phone (Galaxy S5) is on power-saving location mode, which uses wifi only, I cannot re-enable location. It scans for a while, then eventually fails and gives up. No error message, it just stops looking. Same with the Accuweather widget. If I turn on the advanced location services which includes GPS, I can see the phone turn on GPS, track down my location, then I can pick and use it. Not sure if this will enable to weather widget to update, but it appears at least for the GS5 that the widget can't use wifi to find your location. Nor, of course, can you just tell it what location to use.
    Will update once I've been able to determine if this fixed the updating issue or not. Not entirely in love with the idea of keeping GPS on all day just to have accurate weather.
    FWIW, I blame accuweather for all of this. And partially Samsung for forcing us to use it.
  8. #8
    1812dave's Avatar
    Posts
    Global Posts
    10,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    the weather app (using Accuweather) is horrible. Updating frequency is all over the place. for me, it's useless.
  9. #9
    Cherenkov's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No luck. Watch didn't update. When woke the phone I could see it polling GPS to get a location fix, then it updated the weather. It wasn't auto-updating on the phone either. Samsung suggests clearing the weather cache (data reset, so that took care of that for me) and putting the weather app on the lock screen, which you can't even do on the GS5 without a third-party app. So I guess until someone makes an app in the app store with better weather built in (fingers crossed) or Samsung puts out a patch we're stuck.
  1. Charging S5 with micro USB (not micro USB3) charger from S4
    By Dualmonitors in forum Samsung Galaxy S5
    Last Post: 09-04-2015, 09:28 PM
  2. !!! PLEASE HELP ME !!! Shield Software Update 72 doesnt work :(
    By NikolaB_A in forum NVIDIA Shield Portable
    Last Post: 10-21-2014, 11:01 PM
  3. Screenshot not working
    By keri2000 in forum Samsung Galaxy S5
    Last Post: 05-25-2014, 04:08 AM
  4. Replies: 2
    Last Post: 04-15-2014, 03:22 PM
  5. samsung galaxy tab 10.1 will not power up HELP
    By JRitts in forum Samsung Galaxy Tab 10-inch
    Last Post: 04-14-2014, 02:33 PM
