It seems the Music Player is the pre-installed stand alone mp3 player. The Media Controller, separate from the Music Player, plays the music and is not stand alone. Am I right on this, guys?
Also, I just noticed the blutooth headset can't simultaneously work with the phone AND the Music Player at the same time. You either need to disconnect one to make the other one work. For example, you can't simply click on 'Play via BT' while using the Music Player until you disconnect the same BT Headset from your phone, an annoying extra step. Anyone has a similar issue? Thanks in advance.
Sent from my SM-G900T using AC Forums mobile app
