1. mustc's Avatar
    Somehow I disabled the vibration when notifications come in and I can't find the setting to turn it back on.
    Could someone take pity on this poor noob and point me to where the setting is?
    Thanks in advance.
    04-16-2014 09:30 PM
  2. jschu22's Avatar
    Do you have sound? If you turn sound on to any level, you lose vibration. Two finger double tap the home screen to quickly get to settings and see.
    04-16-2014 10:12 PM
  3. Volkers84's Avatar
    On your gear 2, go to settings, then sound, select vibrate. That's my guess...
    04-16-2014 10:22 PM
  4. jordo487's Avatar
    If this doesn't work you may have the gear on mute. Hold down the power button and make sure it is on vibrate or sound.
    04-17-2014 10:24 AM
  5. mustc's Avatar
    Found that with your help. Thank you all. For a while, I panicked and thought I broke the vibration motor!
    04-17-2014 10:02 PM
