1. jaltman's Avatar
    Some are reporting discrepancies between pedometer as measured by Neo vs. a real Pedometer. I am willing to bet distance is calculated by average gait distance based on height. So if you have a real pedometer or are able to measure the distance walked by GPS, try adjusting your height in the Neo pedometer and see what adjustment you have to make to get the distances to match. I bet the rest of us can use that to adjust our height to get a more accurate distance walked.
    mastrodamus likes this.
    04-17-2014 03:14 PM
  2. Brandon Barnes1's Avatar
    It definitely isn't accurate as far a treadmills go. For example using the fitness app on the treadmill I'll be up to 3 miles distance but on the Neo it will say 2 miles. Also the heart rate varies a lot.
    04-17-2014 11:34 PM
  3. Trent9810's Avatar
    On some of my runs compared to a fit bit it is about 50 steps off from what the fit bit says. Still not too bad!
    04-18-2014 10:09 PM
  4. 530XI's Avatar
    I was thinking about this one today and thought that as long as I use the same app, it doesn't matter if it is off as long as I compare the daily results against itself. If it's off 100 steps a day it's consistent against itself. If I want to increase my walk by 2000 steps it is still just adding 2000 steps to the same app.
    04-18-2014 10:18 PM
  1. Camera Error, Can't connect to the camera
    By Brandon Andre in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 03-17-2015, 05:20 AM
  2. SIM Card Error Upon Purchase than the following day
    By chuckd05 in forum HTC One M8
    Last Post: 04-22-2014, 08:20 AM
  3. Skype error locks up my tablet
    By 1Ando in forum General Help and How To
    Last Post: 04-17-2014, 12:14 PM
  4. S4 Android 4.3 - Handcent SMS app in error loop - I can't use phone
    By Christopher Houston in forum Samsung Galaxy S4
    Last Post: 04-17-2014, 06:47 AM
  5. SIM Card Error Upon Purchase than the following day
    Last Post: 04-16-2014, 08:56 AM
