Page 1 of 3 123 LastLast
Results 1 to 25 of 56
Like Tree3Likes
    Default Conserving Battery Life
    What's the best way to save battery life? Do you all keep Bluetooth on all day or only while you drive? Just wanna see what others are doing.
    Thanks
  2. #2
    Default Re: Conserving Battery Life
    My strategy is to find an hr a day to charge it and wear it fully functional at all other times.
  3. #3
    I keep the BT on all day, I use it for running and med msg checking thru the day. And i stll get 3 days of use from one charge. I do however have the brightness low and screen only on when i hit the home button.
    taeisme and dorrien12 like this.
  4. #4
    I use it day and night (sleep tracking) - and always on Bluetooth. Brightness Level 4.
    With wake up screen on movement I get solid 2 days / nights.
    With only on via Homebutton I get 3 days / nights.
    With a very dark wallpaper about a day more.
    I am very happy with the battery life.
    BTW: with Bluetooth connection to my phone on - 7 hours sleep recording uses about 5% battery.
    I think that is awesome as well.
    Sent from my SM-G900F using AC Forums mobile app
    mcm180 likes this.
  5. #5
    530XI's Avatar
    Posts
    Global Posts
    148 Global Posts
    At around 60hrs use I still had about 23% battery left. Good enough for me.
  6. #6
    I'm getting an average of 4 days out of my watch. My setting s at set at vibrate for sound. 2 for brightness. Black background. And I routinely use the voice on with a double press and emails and texting regularly
  7. #7
    Default
    Quote Originally Posted by swade8 View Post
    Update. ... I've recently changed from the motion sensor of waking up the clock to the button only feature and didn't change anything else, and now I'm getting at least 13 and half hours and have 91% battery left. I will keep monitoring it and report back soon after its been a full day or longer.
    Update #2... 37 hours later, settings the same and have 75% battery left on watch.
    Update #3... Currently is been 64 hours now from one charge and my battery is at 49%. I haven't changed any settings and I've answered more calls today than I have in the last few days on it. So far. .. I'm very impressed with the battery life on this watch.
    Update #4... As of this writing, it's been 108 and half hours on one charge and I currently have 27% battery still left.
    Update #5... I ended up getting 120 hours out of my watch, till I got the message at 15% left, stating that it needed to be plugged in for charging. I didn't run the battery any lower because I don't know if it drains quicker or not beyond that point. Also I wouldn't have been able to charge it if it drain quick because I want around a charging source at the moment.
    Conclusion. ... Anyone should should easily get the specified 3 days on a full charge, no questions asked. I will stick with my 4 to 5 days depending on how I use mine. For the most part I do use the heart rate monitor, I make and receive calls, I send and receive texts. I receive emails and the appy alerts along with news Republic and requallable notices. And set the display to 2 during the day as it's plenty bright for outdoors and 1 for night and button on only to view the clock with the black background.
  8. #8
    dimakan's Avatar
    Posts
    Global Posts
    33 Global Posts
    Motion sensor is a huge battery killer. We need some kind of quick settings button. I think it was promised to be available at launch. Ability to quickly turn sleep monitoring on and turn watch-on from motion off, for example.
  9. #9
    jschu22's Avatar
    Posts
    Global Posts
    723 Global Posts
    Quote Originally Posted by dimakan View Post
    I quicker way to do this would be great. I change this setting every night and then in the morning but going into the phone app is quite cumbersome.
  10. #10
    Quote Originally Posted by jbak3r View Post
    Thanks
    I have auto activate off, brightness set to 3. I am on day 2 and my battery is at 83 percent as I check right now.
    Tarek53180 likes this.
  11. #11
    Quote Originally Posted by jschu22 View Post
    Why do you change it every night? When I set my watch to sleep mode and block notifications while sleeping, the motion-on turns automatically off.
  12. #12
    I find a black wallpaper is the best battery saver.
  13. #13
    By chance, are any of you using Watch Styler for various custom watch faces? I seemed to notice a serious drop in battery life right around the same time that the app came out...unfortunately, I am hooked on the custom faces since using them on my Gear 1. So I'm not sure if I will make any changes, but just curious if the app is the reason for the variance.
    mcm180 likes this.
  14. #14
    Do you turn it off at night?
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
  15. #15
    Default
    Do I turn what off at night? I don't turn anything off on the watch. I get notifications all through the night but don't check them till morning. I have the watch screen set to timeout in 30 seconds. Other than that that's it. I also loaded Reqallable and have that check my emails and all other notifications, and the bluetooth stays connected to my phone 24 x 7 as long as it's in range.
    Sent from my SCH-I605 using Tapatalk
  16. #16
    Do I turn what off at night? I don't turn anything off on the watch. I get notifications all through the night but don't check them till morning. I have the watch screen set to timeout in 30 seconds. Other than that that's it. I also loaded Reqallable and have that check my emails and all other notifications, and the bluetooth stays connected to my phone 24 x 7 as long as is in range.
    Thanks that was my question, so you leave the watch on all night. I swapped mine for a new one, the settings are the lowest. I'm gonna see if I can get those numbers.
  17. #17
    Default
    As of this post, I've fully charged my watch last night, it's been 13 hrs and I've used the watch more with voice texting and I'm down 16% on watch battery. And this is also using a watch styler clock face ...But I'll keep you posted.
    dorrien12 likes this.
  18. #18
    Plz do
  19. #19
    You got it.
  20. #20
    Quote Originally Posted by Batman8888 View Post
    I am testing that now so back to the plain ones that came with the watch. Will let you know in a day.
  21. #21
    I too just started using a watch styler face I created last night. Good thought though on the battery drainage issue if any. I just posted a black and white Lion head that I created one over in the watch faces area that was recently created. If interested I'll upload the file.
  22. #22
    So far with:
    Display at 2, screen timeout at 10 sec, wake to button only, and a dark background with dark watch.
    6:55pm to 3:01am battery at 88% (made some phone calls & text messages), leaving watch on and connected to phone, going night night, will report back later.
  23. #23
    9:03am battery at 79%, (6hrs battery drain of 9%, no notifications during that period).
  24. #24
    This is my 2nd update with using the watch styler as clock. .. I've been on now for 38 1/2 hrs and am at 44% battery life left.
  25. #25
    I'm doing the test without WatchStyler, display @ 2, Screen 10 sec, Wake to button, on thru out the night, phone calls & sms (don't want email notifications) so far at 30 hrs, battery at 49%.
  1. Phone Battery Drain
    By itinj6 in forum Samsung Galaxy Gear
    Last Post: 05-29-2014, 08:28 PM
  2. question about charging battery
    By ahawkua in forum General News & Discussion
    Last Post: 04-18-2014, 03:07 PM
  3. Good, Bad & Ugly --- My T Mobile Note 3 Battery Life
    By logoseternal in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 04-18-2014, 02:14 AM
  4. Battery Stats
    By sweetypie31 in forum Samsung Galaxy S5
    Last Post: 04-18-2014, 01:53 AM
  5. Battery life?
    By edge4628 in forum Samsung Galaxy S5
    Last Post: 04-17-2014, 11:24 PM
