1. Marcelo Rivero's Avatar
    Does the screen rotate when you turn it ? I mean, if you put your hand/wrist pointing upwards, is the display supposed to rotate ?
    Mine is not doing it, BUT when it's plugged to the dock and charging it does rotate to any of the 4 sides (up, bottom, left, right) but it stops doing it as soon as I unplugged the USB cable (it doesn't matter if the dock is still attached).
    Thoughts ?
    04-30-2014 01:47 AM
  2. lizardchest's Avatar
    I think that's standard. Probably so you can read it in any position while charging and sitting on your table.
    04-30-2014 06:50 AM
  3. Marcelo Rivero's Avatar
    Yes, but what about when it's not in the docking. It might be nice if it rotates when you use it on the wrist and you put your hand pointing upwards
    05-02-2014 08:37 PM
  4. swade8's Avatar
    No. Mine doesn't rotate on my wrist, only while it's charging does it rotate. But I do see your point.
    StarDon likes this.
    05-03-2014 11:54 PM
  5. Jay Bowe's Avatar
    I found this because I googled the same question. What's weird is mine did it the first day I wore it. I remember specifically because I even pointed it out and showed that exact feature to my girlfriend while I was wearing it. Now it won't do it and I don't know why.
    StarDon likes this.
    06-13-2014 10:37 AM
  6. NoFaQ's Avatar
    I was hoping for a screen rotation 180 degrees option. I like to wear it on my left wrist, and I like the idea of the speaker/microphone being on the right side. For the current setup, it's on they left. So, if I'm wearing a long sleeve shirt, it's common for the sleeve to cover up the speaker/microphone.
    06-23-2014 03:36 PM
  1. gear 2 application challenge
    By Index77 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 08-29-2014, 07:40 AM
  2. Gear 2 / Fleksy
    By bendernyc in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-02-2014, 01:46 AM
  3. Gear 2 how to get to task manager?
    By jayonegame in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 04-30-2014, 02:40 PM
  4. Is Joto Screen Guard interfering with Touch Screen?
    By basspig in forum Samsung Galaxy Tab Pro 12.2
    Last Post: 04-29-2014, 07:09 PM
  5. Rooted Galaxy Gear
    By gunznbutta456 in forum Samsung Galaxy Gear
    Last Post: 04-29-2014, 06:29 PM
