1. xyf80's Avatar
    Found out the Gear 2 weather update is linked to stock weather widget, I can see every time I click update on my S4 it is updated on my Gear 2 and there is no 15 min update option in the widget nor you could change the Gear 2 weather to some other widget in my opinion.
    So what need to be done in order to get the weather update every 15 min?
    05-01-2014 11:39 AM
  2. nklv_aleksa's Avatar
    There's no way you can change that until some other weather app comes out. Accuweather weather info whose data is used on the phone widget is the worst and and least frequently updated information
    05-01-2014 12:30 PM
  3. xyf80's Avatar
    That is what I thought, hope Samsung would get it customized on some degree soon. Thanks for your reply!
    05-01-2014 12:38 PM
  4. kingfisher171's Avatar
    try Rain Alarm for hour hrly updates
    05-01-2014 12:41 PM
  5. swade8's Avatar
    ...... And. .... This works with the Gear 2? How? .....
    1812dave likes this.
    05-01-2014 11:34 PM
  6. kingfisher171's Avatar
    Can you not google for it and install ? or get the app from Playstore?
    05-02-2014 12:04 PM
  7. lizardchest's Avatar
    You do know this is the Gear 2 forum and the Gear 2 runs on Tizen, not Android(therefore no Play Store apps), right?? If you do know that and are suggesting that the Gear 2 pull it's weather info from anything but the stock weather app, it's not able to do that....yet...
    05-02-2014 12:07 PM
  8. kingfisher171's Avatar
    No I hadn't realised that, whoops, my error and stand corrected.
    05-02-2014 12:56 PM
  9. lizardchest's Avatar
    No worries. It looks like it will replace my radar app on my phone, so thanks for the heads up! It would(will?) be nice if they port it to Tizen/Gear 2.
    05-02-2014 01:11 PM
  1. Use Bluetooth Headset for "Speech to Text"?
    By Jon44 in forum Samsung Galaxy S5
    Last Post: 09-28-2014, 11:17 PM
  2. moto X to Italy?
    By steveinil in forum Moto X (2013)
    Last Post: 05-15-2014, 04:51 PM
  3. is net neutrality a good or bad thing for the openness of the internet?
    By ahawkua in forum General News & Discussion
    Last Post: 05-05-2014, 01:57 PM
  4. Replies: 10
    Last Post: 05-02-2014, 05:43 PM
