1. jpriest007's Avatar
    I just found out that the heart rate monitor is accurate. I was at the doctors office yesterday and while they were taking the normal check in vitals. The Gear 2 Neo's heart rate and the doctors were spot on the same.
    05-01-2014 08:13 PM
  2. tcjohnsson's Avatar
    I've found the watch to be very accurate when taking measurements while being perfectly still. However, it's horribly inaccurate (about +/- 50 BPM off) once you start any kind of moderate exercise (i.e. jogging, hiking, etc).
    05-02-2014 03:57 PM
  3. JimSmith94's Avatar
    Thanks, that's reassuring. I just got out of the hospital for an ablation to fix an atrial flutter. My heart rate had dropped into the 30s and I didn't notice it but my regular doctor did at a regular appointment. My Gear 2 is on its way and checking my heart rate will be one of the many uses I plan for it.
    05-02-2014 04:31 PM
  4. 1812dave's Avatar
    I mentioned that a couple days ago. My HR monitor is identical to counting pulse manually. From complaints I'd read about online, I thought the HR feature was a total gimmick.
    JimSmith94 likes this.
    05-02-2014 04:39 PM
  5. tcjohnsson's Avatar
    It's gimmicky insofar that it doesn't perform as Samsung advertised. Those complaints aren't from people stating the HRM cannot take a pulse while standing still. They are complaints from people using the monitor while active. The S5 can also take your heart rate and provide an accurate reading while standing still but is useless at continuous heart rate tracking while exercising (for obvious reasons). The benefit to having an HR monitor strapped to your wrist is that you can monitor and track your exercise sessions. The Gear 2 does not accomplish that as advertised. Just taking a random pulse while standing still? It's 100% on the money. But again, this is not how Samsung marketed their new line of "fitness" trackers.
    05-02-2014 05:14 PM
  6. 1812dave's Avatar
    Yes, I understand what you are saying. It's fine when still, but otherwise problematic.
    05-02-2014 05:25 PM
  7. Trent9810's Avatar
    I find the HR on the neo to be good up to 120 then it starts to way over count apx 30+ on the upper side of things. If you have very hairy arms it can also mess up your HR readings
    05-03-2014 09:50 PM
  8. thegame161's Avatar
    I think it's how you have it on your wrist...
    05-13-2014 01:54 AM
  1. Replies: 1
    Last Post: 02-22-2015, 06:43 AM
  2. have had no issues with HR monitor re accuracy.
    By 1812dave in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-01-2014, 10:11 AM
  3. Replies: 0
    Last Post: 05-01-2014, 01:03 AM
  4. Gear Neo heart rate monitor
    By Hankie Totoro in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 04-26-2014, 04:36 PM
  5. Chromecast and PC monitor
    By losl in forum Google Chromecast
    Last Post: 04-24-2014, 06:56 PM
