1. dorrien12's Avatar
    Has anyone got it to work on a PC/Mouse or a Mac. I watch a lot of online movies; Com cast online and Netflix. Anyone got the IR to remotely control them?
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
    05-01-2014 10:04 PM
  2. Kelly Burby's Avatar
    I think your device supports the IR blaster why don't you installed an application that you can use it over your ....... try using samsung Peel.
    05-02-2014 01:15 AM
  3. dorrien12's Avatar
    Is the IR blaster the same as WatchON remote? And what is Samsung Peel, I don't see it in Sammys app store?
    05-02-2014 06:01 AM
  4. MattKerwin's Avatar
    keep us posted if you are able to do this successfully :-)
    05-02-2014 06:41 AM
  1. How do you remove the smart remote from the lock screen?
    By Shaamoney in forum Samsung Galaxy S5
    Last Post: 02-11-2016, 02:47 PM
  2. Remote Desktop question - Chromebook to Mac
    By ibbyj in forum Chromebooks
    Last Post: 05-13-2014, 10:08 AM
  3. Dash/Dot for channels on Smart Remote App
    By mattred33 in forum Samsung Galaxy S5
    Last Post: 04-29-2014, 08:10 PM
  4. control multiple devices remotely and simultaneously
    By Goldentongs in forum Software Development and Hacking
    Last Post: 04-26-2014, 05:05 AM
  5. ir remote on htc one m8 to sensitive
    By Jeroen van der Schalie in forum HTC One M8
    Last Post: 04-24-2014, 03:48 PM
