Results 1 to 3 of 3
    Default WatchStyler not presenting in Gear Manager
    Hi,
    I've downloaded WatchStyler from Samsung's App site through Gear Manager to my Note 3 (Vz 4.2.2). I can design faces but the Styler doesn't present itself as an option in the Gear Manager. Everything is stock and I'm trying to place faces on the G2.
    Thanks,
    Chris
  2. #2
    ElCamino's Avatar
    Posts
    Global Posts
    28 Global Posts
    Default Re: WatchStyler not presenting in Gear Manager
    Try checking again. Open up Gear Manager, go down to Samsung Apps. You will see category's, chose "Clock" and click on "Watch Style" and double check that it show "Open". If it does, I would uninstall and reinstall.
    SOLVED - uninstalled Samsung App Manager, reloaded from Samsung.com. All is well now.
  1. Dialler - Different Options Being Presented
    By bigmouthmedia in forum Samsung Galaxy S5
    Last Post: 05-04-2014, 08:35 PM
  2. Replies: 3
    Last Post: 05-04-2014, 06:52 PM
