Results 1 to 12 of 12
    1812dave's Avatar
    Posts
    Global Posts
    10,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Steaming music via BT sucked battery dry.
    Roughly 1.75 to 2.0 hours of streaming music to a BT speaker took the battery down from 68% to 1% (critical). Dang, had no idea this was going to happen.
    What about you guys? Does music streaming for a couple of hours knock off more than 50% of battery life of your G2's battery? The speaker was within a foot of the watch and so was the phone.
  2. #2
    mouseglider's Avatar
    Posts
    Global Posts
    1,139 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock - but Rooted
    Default Re: Steaming music via BT sucked battery dry.
    Happens to me too under those circumstances - I believe it is the BT in the phone - same on my Tablets - very inefficient.
  3. #3
    lizardchest's Avatar
    Posts
    Global Posts
    550 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mouseglider View Post
    *watch
    1812dave's Avatar
    Posts
    Global Posts
    10,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can stream bluetooth from my note 2 for hours without sucking the battery dry to the tune of 30 percent per hour
    1812dave's Avatar
    Posts
    Global Posts
    10,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Recharged the Gear 2 to 100%, resumed streaming music via BT, and sure enough, it reduces battery life by exactly 20% per hour. Silly me expected to be able to stream for at least 6 hours. I listen to music frequently and thought the watch would be an excellent way to stream, but using this much juice, I'll have to go back to using something else.
  6. #6
    swade8's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This is a silly question, but are you telling me that you are streaming music from your phone to your watch? Hence causing the watch to drain power hour at 20%?
    Sent from my SCH-I605 using Tapatalk
  7. #7
    swade8's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 1812dave View Post
  8. Thread Author  Thread Author    #8
    1812dave's Avatar
    Posts
    Global Posts
    10,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by swade8 View Post
    NO! Streaming from watch to BT speaker. One of the features is there is room for quite a few music files on the watch and it's designed to be used with BT speakers. But if it's going to lose 20% per hour, THAT IS NOT COOL.
  9. #9
    Hielko's Avatar
    Posts
    Global Posts
    51 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    And your bluetooth speaker uses bluetooth low energy (v4.0)?
  10. Thread Author  Thread Author    #10
    1812dave's Avatar
    Posts
    Global Posts
    10,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No idea. It's a jambox
  11. #11
    Hielko's Avatar
    Posts
    Global Posts
    51 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So that's probably the problem. Regular bluetooth requires too much energy.
  12. Thread Author  Thread Author    #12
    1812dave's Avatar
    Posts
    Global Posts
    10,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can't tell if my jam splash is 4. Tried googling
  1. How Do you stop phone from vibrating when music is playing?
    By Sandy Zeloof in forum Samsung Galaxy S5
    Last Post: 09-02-2016, 04:43 AM
  2. Samsung site has battery charging kit back in stock
    By diamondRanch in forum Samsung Galaxy S5 Accessories
    Last Post: 05-07-2014, 03:08 AM
  3. Issue with Music Player.
    By TB-1599 in forum Samsung Galaxy S5
    Last Post: 05-06-2014, 12:23 PM
  4. google play music question
    By emad1995 in forum Samsung Galaxy Note 3
    Last Post: 05-06-2014, 02:06 AM
