1. ShaggyKids's Avatar
    Has anyone tried switching out to watch bands on either the gear 2 or the gear neo 2? I prefer a metal stretchy watch band over the plastic wear leather type watch band that you have to buckle. I like to just be able to slide my watch on rather than buckling it on.
    I would be looking to find a nice rose gold band to go with the gear 2. They make it look really easy to switch them but actually doing it could be a whole nother story.
    I'm wondering if anyone tried this and how it works for them?
    Deb from my Note 3
    05-11-2014 10:00 AM
  2. lizardchest's Avatar
    Deb from my Note 3
    Check out this thread: Watch Band Photo Thread
    ShaggyKids likes this.
    05-11-2014 10:02 AM
  3. johnmltb33's Avatar
    I changed out my Gear 2 band with a 22mm NATO ballistic nylon band, simply because the stock band was too small. The spring pins that Samsung refers to as presto pins are easy to change as they have an extra little leg on one side to compress them. As long as you are not too short on patience or time it is easy! Whether you can slide the watch onto another band would depend entirely on the band. On mine I had to compress the pins again and fit them in a small area of the band to reattach the watch.
    05-12-2014 12:23 PM
  4. JimSmith94's Avatar
    Compressing the pins is the standard way to attach any watch band. Are you saying you reused the Samsung presto pins on your new band? If so, I guess the leg must have fit inside your NATO band. I doubt that would work on a metal band.
    05-12-2014 04:50 PM
  5. johnmltb33's Avatar
    Yes, that is what I'm saying. The pins will fit inside the NATO band, but there is always the option to replace them with regular spring pins. Amazon carries 22mm pins and a small tool for the job at a very reasonable cost.
    05-12-2014 05:39 PM
  6. dorrien12's Avatar
    I use the regular 22mm spring bar pins and a push pin (big ones) to push the pins out....don't need a tool, her is a pic of the pin I use.
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
    05-12-2014 07:16 PM
  7. ROBNOB9X's Avatar
    I switched and put on this metal strap. Looks so much nicer now and was slightly fiddly but pretty simple to do.
    Sent from my SM-G900F using Tapatalk
    05-18-2014 06:31 AM
  8. Saccs's Avatar
    Here is my watch band... It's has small traces of gold in between the inner links that I found unique.... Click image for larger version.
ID:	118822Click image for larger version.
    Sent from my SM-N900P using Tapatalk
    Attached Thumbnails Switching out the watch bands-uploadfromtaptalk1400446227514.jpg
    05-18-2014 03:50 PM
  9. ShaggyKids's Avatar
    Nice!
    Deb from my Note 3
    05-18-2014 10:56 PM
  10. USF1208's Avatar
    Where did you get those watch faces?
    04-22-2015 06:48 PM
  1. Replies: 6
    Last Post: 05-12-2014, 03:28 PM
  2. No KK for the UK yet?
    By fitcherama in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 05-11-2014, 10:41 AM
  3. switching from Blacbery
    By Pratsen954 in forum HTC One M8
    Last Post: 05-11-2014, 07:43 AM
  4. What's the default password for voicemail?
    By Bayarea13 in forum Samsung Galaxy S5
    Last Post: 05-11-2014, 05:30 AM
  5. ScreenShot while in contact with the screen
    By FreakySheikh in forum Roger's Galaxy S II
    Last Post: 05-11-2014, 03:56 AM
