1. pj737's Avatar
    I went for a 4-mile trail run yesterday and a ton of condensation/moisture appeared INSIDE the camera and IR lens. I took a picture of it yesterday and today. The shot attached is from today. It's so bad the phone won't take pictures. It will but the shots look like the attached image; you can't see anything (that is a picture of a sunflower in decent lighting). I waited 24 hours and the condensation is just as bad as it was after the run. I live in Hawaii so it's very humid but I haven't had any problems with my phone's lens fogging up... or a GoPro I've used before in identical climates. There was no rain when I ran. I also NEVER get my watch wet except when I wash my hands and water splashes up onto my wrist area. I have never once submerged the watch. I only noticed the condensation after the run; it was never there before. Anyone else have this problem? I'm bringing it to the AT&T store to see what they say. I may end up swapping it out for a Gear Neo since the camera is the only additional feature (which is now useless on my Gear 2). Click image for larger version.
Name:	2014-05-11 10.48.31.jpg
    This is a picture of a sunflower
Name:	2014-05-11 13.51.36.jpg
    05-11-2014 07:10 PM
  2. pkcable's Avatar
    Might be worth at least one warranty repair or return, it could be a damaged seal on the camera, that really should not be happening. Definitely sounds like a defect or manufacturing flaw, and grounds to return it!
    05-15-2014 07:50 PM
  3. Maht's Avatar
    I'm so weary. Watch is 5 days old. Same problem. ATT refuses exchange and Samsung wants to put me through the warranty issue. This is obviously a known problem that nobody wants to talk about.
    05-23-2014 12:15 AM
  4. dorrien12's Avatar
    Call retention dept and let them know what a loyal cust you are and how this is not right and how UNHAPPY you are...insist they credit your account for the amount. If it doesn't work the first time, call again (this advice is assuming you are a AT&T cust).
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
    05-23-2014 12:46 AM
  5. jschu22's Avatar
    I don't love suggesting this but given their apparent lack of interest in helping you, just straight up return it to another store without mentioning it. Yes you will lose some on the restocking fee but its better than the road you're going down otherwise.
    1812dave likes this.
    05-23-2014 07:10 AM
  1. Member Shoutouts. How and when.
    By Madd54 in forum Site Feedback & Help
    Last Post: 02-22-2015, 03:35 PM
  2. Nexus 5 and TWC Ubee Modem/Router
    By noskeyz in forum Google Nexus 5
    Last Post: 06-15-2014, 11:06 PM
  3. Replies: 5
    Last Post: 05-15-2014, 08:37 AM
  4. Weather and Briefing Widget
    By mikeprocess in forum Samsung Galaxy Note Pro 12.2
    Last Post: 05-11-2014, 04:59 PM
  5. M8 and Sprint Airwave
    By mfreeland in forum HTC One M8
    Last Post: 05-11-2014, 02:50 PM
