Results 1 to 8 of 8
    Sharpnd152's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Gear 2 Auto-Lock does not function correctly after Kitkat
    Hey everyone!
    I've been trying to find a potential fix, but haven't found anything yet. Before the update, everything worked flawlessly. However, after upgrading to Kitkat today on my Galaxy Note III, the auto lock function is not working properly with my Gear 2 (latest software/updates).
    What's happening:
    Auto-Lock will force you to use a password (in my case, I chose a pattern) ONLY when not in connection distance from the watch. After updating, it requires the pattern regardless of the connection. I've cleared my cache, reset both devices/deleted and re-added via bluetooth multiple times but am having the same result. This does not seem to be specific to the Note 3, because my girlfriend is having the same issue with her Gear 2 Neo and GS4.
    Does anyone have any suggestions or possibly have a Gear 2 and can test out the functionality with a GS4/Note III with Kitkat installed?
    Thanks!
  2. #2
    Hielko's Avatar
    Posts
    Global Posts
    51 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Gear 2 Auto-Lock does not function correctly after Kitkat
    Same problem with Note 2 and Gear 2, after upgrade to kitkat.
  3. #3
    looking4birds#CB's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the same problem. Just updated to Kit Kat today on my Verizon Note 3 and cant get the auto unlock to work. Help!!
  4. #4
    JimSmith94's Avatar
    Posts
    Global Posts
    740 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Freeza'sfre3 KitKat 4.4.2
    I already had KitKat on my Sprint Note 3 when I got the Gear 2, but this works fine for me. In fact it's one of my favorite things about this watch.
  5. #5
    JacksonEdwardHarrison's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I think it is a Verizon Note 3 Kitkat bug. Happened when I updated today as well. I have yet to find a fix.
  6. #6
    alengman's Avatar
    Posts
    Global Posts
    134 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I had the same issue and did a factory reset on the gear and the auto lock is working now. They seem to have added a lock icon when swiping to unlock the phone. I was actually trying to fix another issue when i did the factory reset on my gear 2.
  7. #7
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by alengman View Post
    Thank you!
    Exactly right. It appears to be linked to changes in the lock screen. I was frustrated to have to do the factory reset, but it worked brilliantly. (Be sure to back up your device first folks, it makes things a bit easier to restore. ) Thanks again!
  8. #8
    Scott Weber's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs down Re: Gear Auto-Lock does not function correctly
    I have reset my gear and stil cannot get my Auto lock to stay on. ???
  1. Kitkat 4.4.2 Update effectively kills Visual Voice mail!
    By uberterrific in forum Verizon Samsung Galaxy Note 3
    Last Post: 06-16-2016, 01:46 AM
  2. Gear 2 Auto-Lock does not function correctly after Kitkat
    By Sharpnd152 in forum Verizon Samsung Galaxy Note 3
    Last Post: 06-23-2015, 05:16 PM
  3. Do a factory reset after you download kit kat that will solve alot of problems
    By zaydabarber in forum Verizon Samsung Galaxy Note 3
    Last Post: 05-15-2014, 01:53 PM
  4. Not registered on network
    By AhmadS3 in forum Samsung Galaxy S3 I9300
    Last Post: 05-13-2014, 03:26 AM
  5. Replies: 0
    Last Post: 05-13-2014, 12:34 AM
