05-22-2014 10:10 PM
37 12
tools
  1. 1812dave's Avatar
    its got a new look too.
    TIP: if you want to zoom in on a Route(in Route Details) , double click the map; then you can pinch to zoom in/out.
    05-13-2014 08:33 PM
  2. 1812dave's Avatar
    For the app on the watch, I just realized I have "auto-update" turned on for all apps in Gear Manager. ie, I don't know when apps update, so I don't know what features are added (my phone is set to manually update so I can learn what new features apps get).
    The latest date for MapMyRun is showing as 5/12 and I installed it on 5/8. Does anyone know what changes were made to the app?
    05-13-2014 08:51 PM
  3. JimSmith94's Avatar
    The heart rate sensor on my Gear 2 didn't work before, but with this update it doesn't even find the watch! Is anyone else's working?
    05-13-2014 10:23 PM
  4. 1812dave's Avatar
    Try restarting both hardware and clear app cache
    05-14-2014 12:52 AM
  5. 1812dave's Avatar
    The updated app works for me
    05-14-2014 12:56 AM
  6. JimSmith94's Avatar
    Okay, I tried that but it didn't make any difference. On the old version when I clicked on Heart rate in Sensor Settings, it showed every Bluetooth device I have, even my TV! With this new version, under Scanning for Devices it only has "Use ANT+" whatever that is, and no Bluetooth devices at all.
    05-14-2014 02:52 AM
  7. 1812dave's Avatar
    There is no heart rate monitoring through map my run
    05-14-2014 10:21 AM
  8. JimSmith94's Avatar
    Not sure if you're talking about the watch or the phone, but on the phone there definitely is heart rate monitoring. Go to Settings>Heart Rate, Other Sensors...>Heart rate>Connect, and choose the Gear 2. That worked for me on the previous version but on 3.0.3 all I see for devices is "Use ANT+" whatever that is. No Bluetooth devices show at all, where the previous version showed all available Bluetooth devices, even my TV!
    05-14-2014 12:30 PM
  9. MattKerwin's Avatar
    Is there a way to start tracking the workout from the watch rather than the app...so if the phone is stored you can just start it from the watch?
    Sent from my Samsung Galaxy Note 3 - Android Central Forums App
    05-14-2014 12:49 PM
  10. 1812dave's Avatar
    Here is what happens on my watch.
    If I try to start MMR from watch, the PHONE app begins measuring distance, etc. The watch doesn't do squat. The start button never changes to a pause button and no data ever displays on the WATCH.
    I MUST start from the PHONE app, wait a few moments for the watch app to catch up and everything is synced up from then on.
    No amount of button pushing on the watch app (if starting it first) will get it working...
    Someone should contact the makers of MMR and tell them that the watch needs to work w/o having to open up the phone app FIRST.
    05-14-2014 12:58 PM
  11. 1812dave's Avatar
    After many many tries, the watch app has finally started to initiate a workout AND show data, AND show the pause button. I think by all of the ways I interacted with the watch (taking the app offscreen, then hitting the app icon again to bring it to the foreground) it cleared out something in a cache or something, as it's now working the way we would expect it to. I hope it continues to do that!
    And maybe if i had uninstalled and reinstalled it would have worked.
    lizardchest likes this.
    05-14-2014 01:31 PM
  12. JimSmith94's Avatar
    Glad you got it working! I still can only get the app to show on phone when I start it on the watch. Starting it on the phone still does not start it on my watch.
    1812dave likes this.
    05-14-2014 05:57 PM
  13. JimSmith94's Avatar
    Does anyone else's MMR 3.0.3 on their phone show ANY Bluetooth devices under Settings>Heart Rate, Other Sensors...>Heart rate>Connect? On the previous version mine did, but now it only says "Use ANT+". I can't find any option to tell it to use Bluetooth instead. I was able to connect to my Gear 2 before but I don't see anyway to do it now.
    05-14-2014 06:02 PM
  14. 1812dave's Avatar
    I can't count how many times I tried to get it to work and I was very patient with waiting to see if it would kick in and start working but it wouldn't even after many minutes. I don't really know why it started working today
    05-14-2014 06:04 PM
  15. U4icLab's Avatar
    I'm in the same boat. I did see it briefly after toggling bluetooth on the watch and checking the make visible box. Even then, it still indicated that it was disconnected once connected and no HR data transfer was apparent.
    JimSmith94 likes this.
    05-14-2014 08:45 PM
  16. mgbergman's Avatar
    Has anyone been able to get the heart rate monitor to work with the MMR gear 2 app? I cannot. Please let me know how you were able to get it.
    Marc
    05-16-2014 02:27 PM
  17. 1812dave's Avatar
    Marc
    No, No, and NO.
    05-16-2014 03:27 PM
  18. mgbergman's Avatar
    No, No, and NO.
    So no?
    05-16-2014 03:29 PM
  19. 1812dave's Avatar
    So no?
    Well, maybe its a "maybe" for those who can't handle the truth! Maybe someday it might work? It would have to (obviously) be using TWO BT connections. ALREADY, MMR will drop your battery life at LEAST 32% per hour and maybe closer to 38%.
    05-16-2014 03:31 PM
  20. JimSmith94's Avatar
    Still no solution since the update to 3.0.5, but I did find this on the MMR app support page: https://support.mapmyfitness.com/hc/...he-Android-app
    "Bluetooth Smart and ANT+ heart rate monitors and other cycling sensors have limited support in the MMF Android apps. Android devices running Android 4.3 (Jellybean) will connect with Bluetooth LE heart rate monitors. Some devices with built in ANT+ technology will connect with ANT+ heart rate monitors and cycling sensors. If your Android device is supported by either of these technologies, a "Sensor Settings" button will appear in the "Settings" section within our app. If your "Settings" section does not have an "Sensor Settings" subsection, then your Android device is currently not supported."
    Since my Note 3 shows ANT+ in the heart rate monitor connection, according to this, since I do have "either of these technologies", I should see a "Sensor Settings" button in the "Settings" section but I don't. I have opened a ticket with MapMyFitness but has anyone else been able to connect to their Gear 2/Neo yet, or even have the "Sensor Settings" button in the app?
    05-21-2014 02:50 PM
  21. 1812dave's Avatar
    I have a Heart rate>Connect button (big orange button) in the app on the phone. When I hit it, it doesn't do anything other than momentarily go from orange to white and back to orange.
    05-21-2014 02:56 PM
  22. JimSmith94's Avatar
    When I click the orange connect button a popup with "Select Device" and "Use ANT+" comes up and stays there until I hit the back button. If I click on "Use ANT+" it says "ANT hardware connector disabled".
    I wonder why there are so many differences? I'm on a Sprint Note 3 running KitKat 4.4.2, what phone do you have Dave?
    05-21-2014 04:13 PM
  23. mgbergman's Avatar
    My message on my S4 is the same as yours, Jim.
    05-21-2014 04:33 PM
  24. JimSmith94's Avatar
    Do either of you see "Sensor Settings" button in the "Settings" section of MMR to allow adding Bluetooth??
    05-21-2014 04:43 PM
  25. mpogr's Avatar
    I actually was able to use Gear 2 Neo and my BT LE chest-strapped HRM with MMR. However, for some reason, the HRM connection gets lost very quickly (within a minute) after I start workout. Could be quality of contacts (I didn't manage to buy ECG gel to smear the contacts with, as suggested by the manufacturer).
    Is there any limitation for HRM connection duration built into the free version of MMR? I'm asking because it seems MMR+ has more success with reading HRM data, but the problem is there is still no MMR+ app available for Gear 2 in Samsung app store here in Australia.
    05-21-2014 05:26 PM
37 12
  1. Samsung Galaxy S4 Active Won't Update at All, Still 4.2.2
    By Matthew Covington in forum Samsung Galaxy S4 Active
    Last Post: 12-06-2014, 07:00 AM
  2. Anyone still using the stock keyboard on Galaxy S5?
    By CompMan2012 in forum Samsung Galaxy S5
    Last Post: 05-21-2014, 05:50 AM
  3. Replies: 2
    Last Post: 05-14-2014, 11:04 PM
  4. Where are all the accessories?
    By jetfixer01 in forum Samsung Galaxy S5 Accessories
    Last Post: 05-14-2014, 04:36 AM
  5. Just got the S5 have some questions
    By iamloco724 in forum Samsung Galaxy S5
    Last Post: 05-14-2014, 12:02 AM
