1. ShaggyKids's Avatar
    I've had my watch plugged in to charge it for the past several hours however it won't go over 60%. I turned it off then and continued to charge to see if that made a difference. It still won't go over 60% and in fact now is showing 58%.
    When I first got it a few days ago it charge fine up to 100% Any suggestions?
    Deb from my Note 3
    05-20-2014 02:51 AM
  2. 1812dave's Avatar
    I presume you are using the charger that came with it? If its turned off it should charge up fully in about 2 hours to two hours and 15 minutes. You might try resetting the watch and see if that takes care of the charging problem
    05-20-2014 08:17 AM
  3. ShaggyKids's Avatar
    Yes using the little do-dad that came with it. I unplugged it and then plugged it back in a few hours ago and then it did charge. Maybe it's just a case of I did not have it plugged in properly but I did check that before I posted. We'll see what happens at this point.
    Deb from my Note 3
    05-20-2014 09:56 AM
  1. Why is my phone so slow to charge?
    By DragonMonkey in forum T-Mobile Galaxy S III
    Last Post: 10-08-2015, 01:28 PM
  2. OMG, what have I done
    By IBMJunkman in forum Samsung Galaxy S5
    Last Post: 05-21-2014, 10:12 PM
  3. S3 won't progress past boot screen + sd card issues encryption issues.
    By Snickersthecat in forum Samsung Galaxy S3
    Last Post: 05-21-2014, 01:34 AM
  4. S Note on Verizon GS5...Anyone have it?
    By slb21 in forum Samsung Galaxy S5
    Last Post: 05-21-2014, 01:01 AM
  5. Samsung Galaxy Tab 3 Sound Issues
    By meli smiles in forum Samsung Galaxy Tab 3
    Last Post: 05-20-2014, 06:25 PM
