1. dusty78's Avatar
    So I have downloaded a few apps for my gear 2 (eBay, CNN, flashlight, calculator, map my run etc...) My favorite so far is the instant settings app which controls some of the drop down functions on the phone like wifi, sound, data, etc... I use it all the time to turn my ringer off. It's so simple yet helpful. What about you guys?
    Attached Thumbnails Favorite Gear 2/neo app-20140520_144951.jpg
    05-20-2014 01:50 PM
  2. Tarek53180's Avatar
    the app on your phone that controls those settings whats the name again and will i be able to find it on my samsung gear 2 neo with a samsung gs4
    05-20-2014 02:26 PM
  3. ATT.Fan1982's Avatar
    My favorite app for now is the watch styler app
    Sent from my SM-N900A using Tapatalk
    05-20-2014 02:35 PM
  4. 1812dave's Avatar
    For native apps, I like WatchON Remote the best.
    05-20-2014 03:03 PM
  5. lizardchest's Avatar
    It's an app on the watch. It is a free app called Instant Settings. Works on the Neo
    05-20-2014 03:08 PM
  6. dusty78's Avatar
    for downloaded apps, I like:
    1. Instant Settings
    2. News Republic
    3. Appy Geek
    4. MapMyRun (my big gripe is it uses over 30% / hr, so not conducive to using for an extended period)
    Does your map my run app show you your distance/data on the watch? Mine will start the phone app for a run but doesn't show me any info on the watch itself.
    05-20-2014 03:16 PM
  7. 1812dave's Avatar
    yes it shows me everything. Are you sure u waited long enough? it takes time for it to sync up with the phone's app.
    05-20-2014 03:45 PM
  8. dusty78's Avatar
    I ran 4 miles today and it never showed anything
    1812dave likes this.
    05-20-2014 06:41 PM
  9. Jens Hjorth's Avatar
    I also love the "instant settings" app! However I would really like to see if they could add info for watch battery and the phone's battery info, that could be a really handy feature.
    Also i would love to see a quick settings shortcut (When i go to bed with the watch on, i always disable the screen wake up function, so it can only be activated by pressing the button) Would be very cool to see a feature that worked a little bit like "Tasker".
    05-21-2014 01:37 AM
  10. ATT.Fan1982's Avatar
    You guys have to check out the "confusion" app, loads of fun lol!
    05-21-2014 10:27 AM
  11. Daimon Walker's Avatar
    I'm being dumb. Where are you searching for these apps? Samsung apps or Google play?
    06-04-2014 05:07 PM
  12. lizardchest's Avatar
    You need to go into Gear Manager, then select Samsung Apps to find apps for the Gear. It doesn't show anything if you search Samsung Apps outside of the Gear Manager.
    06-04-2014 07:47 PM
  13. jmatteis's Avatar
    I am unable to access Samsung apps through my Gear Manager. This is only since this morning when my Phone automatically installed the new update. Not sure what to do. I click on My Apps, it works, I click on settings, it works, I click Samsung apps, nothing???
    Okay, found out I had disabled Samsung apps, but now that it is enabled, from gear manager, I click Samsung apps, it brings me to the regular Samsung apps app, nothing specific for the gear though, am I doing something wrong here? if I search instant settings, I find nothing either. It's like my gear manager is going to the regular Samsung app and not one that would indicate I am trying to find gear apps, same thing is happening if I go to my camera and click downloads under mode.
    07-09-2014 02:29 PM
  14. clitrenta's Avatar
    Well, if you go by what I use on a regular basis:
    1. Pedometer
    2. Exercise (walking)
    3. S Voice
    4. Accuweather
    Recent Additions:
    News Republic and CNN (news junkie)
    07-09-2014 03:41 PM
  15. NoFaQ's Avatar
    1. Strava
    2. EasilyDo
    3. Media Controller
    4. WatchON
    5. NewsAce
    07-09-2014 04:03 PM
  16. maggieo's Avatar
    Hi there - hope you can help me. Trying to set up WatchON for my TV and AC. When in the app on the watch, only a few brands showed up. I did "something" after an hour of messing around, and this "all brands" showed up at the bottom! It was great - but it was for the TV - and I found my brand and set it up - perfect! NOW - I need to get that "all brands" option to show up under Air Conditioners, and I can't figure it out. I have no idea how I did it for the TV - but all of a sudden it appeared. Samsung was totally unable to help. Any help from you folks would be GREATLY appreciated.
    08-05-2015 09:14 PM
  17. godzillinois's Avatar
    Watch Styler WOULD be my favorite if it didn't cut my battery life by a third whenever I use a watch face with it. The app I use the most is Fleksy Messenger, easy (if not a little slow) to type even with the small screen, love having that option when I don't want to talk into my watch to reply to a text.
    What's the "Instant Settings" app everyone talks about? When I search for that in the Gear store "Quick Settings" comes up and that's it
    08-07-2015 04:39 PM
  18. catnjr's Avatar
    I can't get this to work on the Gear 2. It loads on my phone, I can add a watch face, but isn't recognized on the gear manager. Any suggestions?
    08-08-2015 11:29 AM
  19. catnjr's Avatar
    There's another question...on the weather app (accuweather, I assume), each time I try to open the weather icon, it says to "turn on use current location on mobile device". I have done that, redone it and even rebooted both devices and continue to get that same message. How did you get yours to work?
    08-08-2015 11:32 AM
  20. NoFaQ's Avatar
    Here's the steps I did to make sure I got the Weather to work. In Gear Manager, go to My Apps, scroll down to Weather and click on the gear on the right side. The, click on Use Current Location and turn it on. Make sure Show Weather Updates is checked. Also, set your Auto-Refresh for how accurate you want the weather to be. I keep it on 1 hour, but set it to what you want. That should keep your Weather on the Gear up to date and functional.
    Any settings in any other weather app do not carry over to the gear. Only inside the Gear Manager.
    08-10-2015 11:26 AM
  21. debdroid1a's Avatar
    I have Flesky and AnalogWatch on my 2 Neo. The Analog watch is the only watch face I use. It has the analog and digital time, the date, as well as a battery bar across the top. Plus I can change wallpapers to mach my skirt or just some fun ones. They do have to be darker because the time, date and battery bar are white, so I just edit the photo and make it a little darker if needed.
    09-10-2015 10:39 AM
  22. NoFaQ's Avatar
    My overall favorite is Gear Tasks by devinci.
    09-11-2015 11:37 AM
  23. haus's Avatar
    My notes in gear. When I drive near a store I've pre-set, I get an alert and my shopping list shows up on my wrist. Brilliant and functional, well written app.
    Sent from my SM-N920V using Tapatalk
    10-03-2015 03:52 PM
  24. rsmith1131's Avatar
    What app is it for the notes and shopping list?
    11-01-2015 10:28 PM
  1. S5 on AT&T - what apps are unnecessary bloatware?
    By woahohkelsey in forum Samsung Galaxy S5
    Last Post: 05-21-2014, 10:04 PM
  2. Stopping apps from startup.
    By droidntn in forum Samsung Galaxy S4
    Last Post: 05-21-2014, 05:57 AM
  3. Error message in stock email app. Can't reply to emails.
    By damnyankees in forum Motorola Droid MAXX
    Last Post: 05-20-2014, 08:48 AM
  4. app to read my emails and texts for car dock
    By smokawhat in forum HTC One M8
    Last Post: 05-20-2014, 08:39 AM
  5. thread w/all the links to watchbands for Gear 2?
    By ShaggyKids in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-20-2014, 07:58 AM
