Results 1 to 15 of 15
Like Tree1Likes
  • 1 Post By Index77
  • 1 Post By 1812dave
    kazrim's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default gear 2 neo music player
    I've transferred a few mp3 folders/files to the neo but the player only lists and plays them as single tracks. Is there a way to access and play them as albums and not just shuffled album tracks played alphabetically.
  2. #2
    Index77's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: gear 2 neo music player
    Can you specify more what do you want. I might create alternative standalone music player
    what about "folder audio player" suitable for audio books and albums with more features?
    kazrim's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I want to play a full album ie tracks 1-10 in the order intended and by the same artist.
    At the moment I have put 5 different albums into the neo but the neo doesn't seem to have the option of playing each album separately. it just plays tracks ie. track 1 from album 1 and then track 1 from album 2 or just plays all the tracks from all of the albums alphabetically ie. track named alpha from album 3 and then track named ant from album 1 and then track named arise from album 5 etc
    is there something I'm not doing correctly, missing, or should the folders etc be in a certain format or is this just the way the player on the neo does things.
  4. #4
    Index77's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    actually you can play music by folder. click on the top-right button --> click on the top right button --> navigate to folders list and click on first item and then music will play in order
    JimSmith94 likes this.
  5. #5
    Mike Di Gaetano's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I picked up the gear 2 neo and the Galaxy S5 and can't seem to sync my music. Little help please
  6. #6
    lizardchest's Avatar
    Posts
    Global Posts
    550 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Mike Di Gaetano View Post
    You are somewhat limited moving tracks over, by BT connection. I believe it's ten at a time:
    Gear Manager>My Apps>Music Player settings icon. Selct your songs, wait a bit for transfer, should show up on your watch!
    Also, by connecting to your pc via USB, I think you can drag and drop.
  7. #7
    1812dave's Avatar
    Posts
    Global Posts
    10,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by lizardchest View Post
    yes, it is 10 at a time. kind of a drag when you want to send 100 or more songs to the watch as I have.
    kazrim likes this.
  8. #8
    denverbob's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can't seem to view these tracks by folder. They just show up as one big list alphabetically. I tried your upper right corner twice tip and that just brings up playlists. An alternate player would be great.
  9. #9
    denverbob's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    zzz
  10. #10
    clitrenta's Avatar
    Posts
    Global Posts
    1,490 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I only put a small amount on mine but unfortunately, My Note 3 will only connect to either my Gear 2 or my LG BT Headset but not both at once. Rather annoying but whatever. Gear comes first.
  11. #11
    Alison Woods's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My gear 2 neo isn't showing up my computer.. when I plug it in it starts to charge but the computer isn't showing the gear anywhere... I wanted to transfer music onto my watch.
  12. #12
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    fixed it sorry
  13. #13
    NoFaQ's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by clitrenta View Post
    I have the Jaybird Freedom BT earbuds, and I can connect them and the watch at the same time. From the phone, I can still switch the call between phone, earbuds, and watch.
  14. #14
    Suzi Smith's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes you can ! Just connect gear to pc, allow to install and then simply drag and drop music to music folder! :o)
  15. #15
    Neverlift's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Has anyone successfully transfered music to the gear 2 neo via the gear app music dial send songs to...etc?? Im using the Note 4 with Gear 2 Neo, Thanks! *Solved*
  1. Favorite Gear 2/neo app
    By dusty78 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 11-01-2015, 11:28 PM
  2. Gear 2 Neo - Lockscreen issues (lag?)
    By Jens Hjorth in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-15-2015, 07:54 AM
  3. moving music files. creating folders
    By Amy Marie4 in forum Samsung Galaxy S4
    Last Post: 05-22-2014, 09:10 AM
  4. media player for iphone videos
    By xmostwanted559x in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-21-2014, 12:37 AM
  5. thread w/all the links to watchbands for Gear 2?
    By ShaggyKids in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-20-2014, 08:58 AM
