1. U4icLab's Avatar
    I have a Gear 2 Neo paired with an S5. Recently, when an update to a Gear app tries to install, I receive an error stating that the device has lost its connection, etc. Samsung apps hangs while installing and requires a force quit. I cleared the caches and did restarts. Anyone else experiencing this? I thought I would ask before going through factory resetting crap.
    New apps install fine, and ones requiring an update can be removed and reinstalled with their updated versions just fine.
    05-30-2014 02:58 PM
  2. swade8's Avatar
    I was getting that too, till I read that you have to uninstall the app that has an update available first, then go back and get the update [which won't say update anymore] and install the"updated app". No need to reboot device or watch. Unless it's a true issue with bluetooth . At least that's what I had to do to fix my loss of connection message when I do my app updates.
    Sent from my SCH-I605 using Tapatalk
    05-31-2014 08:57 PM
  3. four2theizz0's Avatar
    Hi,
    I have the same problem. Not sure what the cause is but have had to resort to uninstalling and reinstalling. Which works but I'm guessing isn't the desired UX Samsung was going for.
    06-01-2014 09:14 PM
  4. Batman8888's Avatar
    Yep, I have the same problem, and I think uninstalling then reinstalling is the only fix.
    06-02-2014 01:10 PM
  5. Volkers84's Avatar
    Same problem here
    06-02-2014 09:43 PM
  1. Before you decide to upgrade
    By Peaches36 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-19-2014, 12:11 PM
  2. Getting my Note 3 to be awesome again after a factory unlock
    By IAmAnOptimist in forum Samsung Galaxy Note 3 Rooting, ROMs, & Hacks
    Last Post: 06-05-2014, 02:52 AM
  3. Which one to buy?
    By Rajeev Kumar5 in forum Moto X (2013)
    Last Post: 05-31-2014, 01:23 PM
  4. Water damage to phone
    By gjones1 in forum Samsung Galaxy Ace
    Last Post: 05-30-2014, 05:52 PM
  5. Replies: 3
    Last Post: 05-30-2014, 04:32 PM
