1. Mimut Rice's Avatar
    I noticed that each type of volume setting (notification system etc) has their own volume options. Is there a way to put everything on vibrate at the same time or do I have to go in and manually set each one? I'd love to have them all set to my preferred settings and then just be able to toggle the vibrate off/on as needed.
    06-07-2014 10:56 AM
  2. JacksonEdwardHarrison's Avatar
    Double tap your home screen with two fingers. Turn device down to vibrate there.
    06-08-2014 11:46 PM
  1. multi window option greyed out
    By EverettS in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 07-30-2014, 12:29 AM
  2. Android 4.2.1 Wifi Never shut off option does not exist
    By Christopher Goslant in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 06-06-2014, 06:46 PM
  3. Developer Options
    By dkjames71 in forum Samsung Galaxy S5
    Last Post: 06-06-2014, 10:00 AM
  4. Best option when using Chrome Remote Desktop
    By rjl2 in forum Chromebooks
    Last Post: 06-03-2014, 09:09 AM
  5. Developer Options - Mock Location
    By Greg C in forum Samsung Galaxy S5
    Last Post: 06-03-2014, 12:39 AM
