1. joseatnj's Avatar
    Just bought the s5 and the gear2 and after finally syncing the phone with the watch (not an easy task) I open the gear manager app and every option I select automatically blinks then brings me back to the gear manager home screen basically I can't make any changes please help I have 12 more days before I have to return this watch and I really don't want to.
    06-10-2014 10:04 PM
  2. charlos81's Avatar
    I have the exact same problem and yours is the first post I've found about this issue. I ended up doing a factory reset on the phone to get the Gear 2 neo to work, and it did for a while, but now I'm having the same problem again. No idea how to fix this.
    06-16-2014 09:45 PM
  3. Abel Castellon's Avatar
    I too am having the same issue. Had the phone and the gear 2 for 2 weeks also before I had any issues. Tried Uninstaller the gear manager and reinstalling. Had tons of trouble reinstalling it and when it did the issues started up again. Every option that is pressed flashes the next menu for a split second and goes back.
    06-24-2014 08:59 AM
  4. joseatnj's Avatar
    I figured it out you have to take the phone off developer mode
    Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
    06-24-2014 09:06 AM
  5. Abel Castellon's Avatar
    WOOOOW. That actually worked. Thanks for the input! much appreciated!
    06-24-2014 05:46 PM
  1. galaxy gear 2 blurry pictures from camera
    By rabidewok in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 07-21-2016, 02:00 PM
  2. galaxy gear 2 blurry pictures from camera
    By rabidewok in forum Samsung Galaxy Gear
    Last Post: 09-12-2014, 05:08 PM
  3. Watch styler App...
    By bbogert79 in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 06-12-2014, 09:28 PM
  4. Lag while updating apps
    By puremeerkat in forum Samsung Galaxy S5
    Last Post: 06-11-2014, 01:15 AM
  5. [FREE][App] Stop The Hero
    By fanling3 in forum Android Apps
    Last Post: 06-10-2014, 09:47 PM
