Results 1 to 9 of 9
    Default sleep mode. how it works?
    I wonder if it really works? And how it works at night? Gear 2
  2. #2
    Default Re: sleep mode. how it works?
    You wear the watch to bed. Before you doze off, you need to start the sleep mode. When you wake up, you press the stop button in sleep mode. There is an option to "block' incoming alerts, so as not to disturb you. After running through a sleep cycle you are able to view how long you were active (arm moved) and how long you were inactive (arm didn't move). Not a totally reliable indicator of the quality of your sleep.
    Thanks but I now functions
  4. #4
    I guess I don't really understand your question, then. Are you asking if it is a gimmick? Somewhat. Are you asking about the usability of the data it shows? As I stated, not a true indicator of quality of sleep.
    Literally, how does it work? By tracking movements. Or do you mean does it work different at night vs during the day? Works the same no matter what time of day or night as long as you're sleeping.
  5. #5
    JimSmith94's Avatar
    Posts
    Global Posts
    736 Global Posts
    Carrier
    Freeza'sfre3 KitKat 4.4.2
    Quote Originally Posted by lizardchest View Post
    I haven't tried the app yet, but I just looked at it and I don't have an optional blocking mode. When I start it, there is a message that blocking mode is enabled, but no option to turn it off. Is that what you see or could we have different versions? My Gear 2 is on NE5 and Gear Manager is 2.1.14052101.
  6. #6
    My Neo is on ND8, Same as you for GM.
    I get no alert when I open the app. When you hit the settings in the top right corner, what do you see? Only History and Help?
  7. #7
    JimSmith94's Avatar
    Posts
    Global Posts
    736 Global Posts
    Carrier
    Correct, I only see History and Help.
  8. #8
    I HATE to suggest factory reset for Gear and/or phone, but it seems like a reset has cleared up a wide variety of problems in these forums... Would it be that bad to just have the alerts blocked? Or are you like me, and refuse to settle for not having an option to change it - even if you won't exercise that option?
  9. #9
    JimSmith94's Avatar
    Posts
    Global Posts
    736 Global Posts
    Carrier
    I didn't look at the Sleep app when I was on ND8, but I did reset the Gear 2 prior to installing NE5 a couple days ago. I'm okay with it defaulting to blocking mode. I'm retired and don't want to be woken up for any notifications, least of all from my watch. Just sleeping with a watch on might be more than I want to put up with.
  1. The vibrate mode on my phone will not work
    By kaylamarie91110 in forum Droid RAZR HD
    Last Post: 11-30-2016, 08:48 PM
  2. Notifications not appearing since using ultra power save mode
    By martinmacrae83 in forum Samsung Galaxy S5
    Last Post: 07-23-2016, 01:45 AM
  3. samsung galaxy note 10.1 not working
    By Dania Ayad in forum Samsung Galaxy Note 10.1
    Last Post: 03-09-2015, 07:46 AM
  4. How to remove NO SIM NOTIFICATION
    By kchtwd09 in forum Sprint Samsung Galaxy S4
    Last Post: 07-01-2014, 04:53 PM
  5. Failed to enable Private mode.. How to solve?
    By Masum56k in forum Samsung Galaxy S5
    Last Post: 06-11-2014, 12:56 PM
