Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By U4icLab
  • 1 Post By U4icLab
    Default Gear Navigator Added
    In my Gear 2 app store, it's showing a new app called Gear Navigator. It installs a Gear Navigator app on your phone and an app on your watch. They sync together and you pull up a map on the phone app and it sends the map info to your watch, once you set a destination.
  2. #2
    philmair's Avatar
    Posts
    Global Posts
    113 Global Posts
    Default Re: Gear Navigator Added
    Where are you looking ? Can't see it in my Samsung Gear Apps.
  3. #3
    I don't have it either. S3/Neo/US Cell/Midwest
  4. #4
    not here either (calif )
  5. #5
    Have it... I'm in CA. I typed in Starbucks and it defaulted to Moscow lol. I'd say, you're not missing much.
    1812dave likes this.
  6. #6
    Quote Originally Posted by U4icLab View Post
    what version of GM do you have (or DID you have when you found/downloaded that app)? i'm on ...101
  7. #7
    Quote Originally Posted by 1812dave View Post
    2.1.14062401. It was present for me before & after the update this morning. I have a 2 Neo paired with an ATT s5
  8. Thread Author  Thread Author    #8
    It's quite good for what it is, one you learn its limitations. It doesn't do nearby searches. You have to know a location. Also, you have to include a city or zip code or you get whatever it pulls up, like you did.
    Sent from my iPad using Tapatalk HD
  9. #9
    I have it to. I did get one or two updates to Gear Manager this morning (couldn't tell if it was one or two) so it may be in there.
  10. Thread Author  Thread Author    #10
    I'm currently on 2.1.14062401, but the Navigator showed up after I installed the Gear Manager update prior to this one.
  1. Custom sync & Adding Calendar
    Last Post: 09-05-2014, 12:35 AM
  2. Help with Galaxy Gear stuck in Downloading Mode boot-loop
    Last Post: 08-26-2014, 10:06 PM
  3. Firmware upgrade encountered an issue on GALAXY GEAR
    By Roger Skepple in forum Ask a Question
    Last Post: 07-05-2014, 08:10 AM
  4. Samsung Gear 2 Neo Compatibility
    Last Post: 06-24-2014, 02:04 PM
  5. Adding Multiple PDF files from box.com to an Email
    By diego.roscetti in forum Samsung Galaxy S5
    Last Post: 06-24-2014, 11:38 AM
