Results 1 to 15 of 15
    Sammuel1973's Avatar
    Posts
    Global Posts
    1,063 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Speaker not as loud and sound is garbled
    It was fine when I bought it at launch. I use SVoice for almost all features. Anyone has similar experience and solution?
    Sent from my SM-G900T using AC Forums mobile app
  2. #2
    lizardchest's Avatar
    Posts
    Global Posts
    550 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Speaker not as loud and sound is garbled
    Did you submerge it or wear it in water?
    Posts
    Global Posts
    1,063 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yeah, I thought of that possibility. The closest of that is cleaning it with a damp paper towel as needed, and immediately drying it. I may have to contact Samsung for an exchange, most likely a refurbish one which I would hate. I absolutely love my device otherwise.
  4. #4
    Posts
    Global Posts
    550 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's the only thing I could come up with. Maybe someone else has had the issue and resolved it themselves. Maybe try shaking the **** out of it or give it a "Fonzie" elbow.... Those are my go-to's when something doesn't work right...
  5. #5
    1812dave's Avatar
    Posts
    Global Posts
    10,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Its hard to control the amount of moisture on a paper towel, compared to a large cloth. I lightly spray [whatever chemical/water] on an old tee shirt in order to limit the amount of moisture transferred to the delicate item i'm cleaning.
    Posts
    Global Posts
    1,063 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Good advice regarding the amount of moisture, but I would think it would not be an issue since it should be water resistant, oh well. The problem started a week ago, so whatever possible moisture should be gone.
  7. #7
    1812dave's Avatar
    Posts
    Global Posts
    10,507 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sammuel1973 View Post
    I didn't mean to imply that there was any damage done from the cleaning. I was just mentioning it for general information
    Sent from my SCH-I605 using AC Forums mobile app
  8. #8
    NoFaQ's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just curious, have you exercised with it? Just thinking of sweat and/or body oil getting in it. I have ran in mine, using the Strava app, and wipe it down, with a damp cloth, after each run.
    Posts
    Global Posts
    1,063 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks everyone for your input. Something weird happened this morning. When I turned on my G2, the screen showed the attached. I waited for 10 minutes, nothing happened so I turned it off. Miraculously and coincidentally , the speaker and sound is back to normal.
    I love my device so much, always use SVoice for texting, taking calls, making appointments, voice memos, etc. Perhaps the problem had to do with the over usage of SVoice? The only time I use my main device, SG5 is for web browse, video, and email.
  10. Thread Author  Thread Author    #10
    Posts
    Global Posts
    1,063 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sorry, forgot to attach the picture.
    Attached Thumbnails Attached Thumbnails Speaker not as loud and sound is garbled-1403883481953.jpg
  11. Thread Author  Thread Author    #11
    Posts
    Global Posts
    1,063 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hey folks. Just an update. Recurring same issue on my Gear 2 despite my last post, so frustrating. You folks are right, seems like the main issue came from the sweat from working out and the hot and humid weather. Sweat and moisture seem to accumulate in the speaker. It is annoying to constantly wipe them dry throughout the day to regain the normal sound quality and volume. I just don't understand why the speaker is placed right underneath the device. Why can't the speaker be placed on the side or on the top??? Am I the only one to have this problem?
    Attached Thumbnails Attached Thumbnails Speaker not as loud and sound is garbled-1404053703045.jpg
  12. #12
    JRenzel's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My watch is having the same issue. I didn't submerge it or anything like that. Just normal daily use. I think Samsung has an issue they need to address with this. I'll probably be returning mine. It sounds like the woman who swallowed a fly ...
  13. #13
    NoFaQ's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Put some rubbing alcohol on a paper towel and clean the speaker/mic area well. This will clean out the speaker/mic section. I run 3-4 times a week, so I clean it with water most days, and alcohol in the one spot 1 every 2 weeks. Every time I noticed a garbled speaker, this clears it up.
  14. Thread Author  Thread Author    #14
    Posts
    Global Posts
    1,063 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by NoFaQ View Post
    Great advice with the rubbing alcohol. Hopefully the speaker in the next generation is placed elsewhere to prevent sweat accumulation. I no longer own the Gear 2, now have the Gear S, same issue unfortunately.
  15. #15
    Jude526's Avatar
    Posts
    Global Posts
    5,945 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't suggest rubbing alcohol. I would use an eyeglass cleaner non alcohol with a micro fiber soft cloth. Paper towel can scratch h the screen. Spray on cloth. Not directly on watch
  1. Best LG G Watch and Samsung Gear Live Screen Protector
    By TizenGears in forum Android Wear
    Last Post: 07-07-2014, 02:17 PM
  2. Do not disturb exception
    By TimmE in forum HTC One M7
    Last Post: 06-30-2014, 06:36 AM
  3. How come my question has not been answered yet
    By jabwtv in forum Ask a Question
    Last Post: 06-26-2014, 09:19 AM
