Can you install android running on the Galaxy Gear Live on the Gear 2? Will I lose camera function? Thank you in advance.
You have to wait for some developers to hack it and install custom ROM and yes you will probably you will loose the camera. You will also loose the ability to have 3rd party "standalone" apps on your watch (that's from what I read), which means all apps now are only android apps sending notification or taking request from watchCan you install android running on the Galaxy Gear Live on the Gear 2? Will I lose camera function? Thank you in advance.
there will be available standalone app for Android Wear, Google hold the developers to release and upload the apps until July 7 that is according to the report
Debating if I want to send back my Gear 2 and get the Gear Live, really like the cross talk on the Google Now that the Gear 2 doesn't have.
Any chance you'd be willing to start a Tasker/Gear 2 thread? I've messed around a bit with Tasker, awhile ago, and would love to see what people are doing with the Gear 2 and Tasker!For now i have a integration with Tasker
Well i bought my Samsung Gear 2 Neo last week. I very carefully made this choice, l looked at the LG G Watch for the Android Wear. But this is so primitive and premature, i decided against it.
Also reviews say the same, and all are waiting for the Moto 360 to come out.
Lets hope that someone makes a ROM for the Gear 2, or to Android Wear in a year or so. When it's more mature. Then the Gear2 will have a new makeover without needing to buy another.
For now i have a integration with Tasker, getting notifications and using the Android Alarms. Using Gear Tasks for shopping lists. Voice memo's on the watch. So everything (for now) when outdoors and having the phone in the pocket.
Maybe the 1st Gear generation apps will be ported to the Tyzen Wear OS, since the Gear has been upgraded to Tyzen also.
