Results 1 to 14 of 14
    Question S-Voice is missing on my Gear 2!
    Hello.
    For some reason, S-Voice is not on my Gear 2! I have it installed on my S4, it just isn't on my Gear!
    Please help !
  2. #2
    Default Re: S-Voice is missing on my Gear 2!
    Not sure what to tell you besides from the factory it is located on the very 1st scree (from the watch face, swipe to the left twice).
    Nope, not there or in "Apps"
  4. #4
    In the gear manager, on the phone, can you go to the settings and change what the double press home button does to S-Voice? Then, see what happens when you double press the home button. Does it pull up S-Voice?
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    Quote Originally Posted by NoFaQ View Post
    I can't find the option!
  6. #6
    You can do it on the watch or the phone app.
    On the watch, goto settings, double press, and change to S-Voice.
    I am really dumb, sorry, there IS a S-Voice option on the phone. But not on the gear. I tried it, but it did not work, it didn't bring up anything. AND on the Applications list on the Gear Manager, I saw S-Voice! But still, not on the gear...
  8. Thread Author  Thread Author    #8
    Anyone?
  9. #9
    call samsung perhaps...
  10. #10
    That is too weird. Try this again. Go to Apps on the Gear 2, then in alphabetical order, you should see SVoice, after Pedometer. If You can, take a screen shot pic to show us what you have on your device.
    Sent from my SM-G900T using AC Forums mobile app
  11. Thread Author  Thread Author    #11
    Here is what I see....
    EDIT: Lag! Look below.
  12. Thread Author  Thread Author    #12
    This is what I see:
Name:	2014-07-03 10.08.50.jpg
  13. #13
    what does that prove? my icons aren't even in that order. besides which, there are a lot more screens of icons, as noted by the graphic at the bottom of the screen.
  14. #14
    Very odd. Assuming you didn't mess with the order of apps or add apps, the order should be in alphabetical order. At least for mine, S Voice is after Pedometer and before Schedule. If you can't download S Voice from Samsung Apps, do an exchange.
  1. Replies: 1
    Last Post: 07-12-2014, 02:00 PM
  2. Is it possible to install android wear on gear 2?
    By polsoft in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 06-27-2014, 08:39 AM
  3. Android l has my nexus stuck
    Last Post: 06-26-2014, 10:45 PM
  4. Hangouts add-on
    By The Rock in forum Ask a Question
    Last Post: 06-26-2014, 09:32 PM
  5. How easy is iTunes to use on s5
    Last Post: 06-26-2014, 08:20 PM
