1. Vanessa0831's Avatar
    Has anyone noticed that the stopwatch app only goes up to 60 mins and then restarts at 0 after that? Also the timer only goes up to 90 mins, which doesn't work for me. Is there any better timer/stop watch apps? I need it for work, but I also read somewhere about an app called Time stream that will give you interval notifications, which would be great for runs! I just can't seem to find it in the samsung app store. Not a very big selection i'm afraid
    07-05-2014 01:56 AM
  2. Index77's Avatar
    my app vCounter is up to 99 mins and 4 countdown/countup timer
    07-05-2014 08:20 AM
  3. prubin's Avatar
    Does it work with voice commands?
    07-05-2014 03:04 PM
  4. Vanessa0831's Avatar
    Thanks Index77 for the info! I wish it went longer then 99 mins though, I need a timer for work, i'm a flight attendant, and some of our flights are over 4hrs! I also wanted a Hiit interval timer for working out, but I don't think there are apps like that yet. I'll def keep my eye on the vCounter though, thanks again
    07-05-2014 04:18 PM
  5. Index77's Avatar
    I am planning to update this app to hours:minutes mode in next update. However, it might work in a different way to save battery!
    Update may come after 1 months from now since I am working on more apps for Gear
    I don't know what is Hiit interval timer! If you explain how this is useful I might code a new app
    07-06-2014 03:04 AM
  6. Index77's Avatar
    No, but you can record voice note
    Is not possible in current version of Tizen. Tizen for wearable is still beta
    07-06-2014 03:06 AM
  7. Vanessa0831's Avatar
    That would be awesome if you could do hours:minutes mode! I would totally use it then
    The interval timer would work something like this: Work for a certain time period and rest for a certain time period. Like 1min on 30 sec rest, 10min run 1 min walk. Because the watch vibrates it would let you know when each time is up There are apps like that for the phone already: Interval Timer, A HIIT Interval Timer, etc. Take a look so you can see what I mean Really appreciate the update
    07-06-2014 12:39 PM
  8. Index77's Avatar
    I think it is good idea to do HIIT timer. It may have limits .. gear is not a phone. Things are limited
    If you tell me how you would use it in your job, I can do it better.. I mean how many timers, max time, etc..
    07-06-2014 03:41 PM
  9. Vanessa0831's Avatar
    The HIIT timer I would use for working out. An Hours:min mode timer is what I would use for work
    07-10-2014 06:16 PM
  10. Vanessa0831's Avatar
    Just found this app today: Interval alarm. Its awesome for work outs with intervals! You can program your work and rest and get notified! Looking forward to using it
    07-16-2014 01:15 PM
  1. SD software bug or hardware issue?
    By isosunrise in forum Samsung Galaxy Tab S 10.5
    Last Post: 02-11-2017, 12:14 PM
  2. Replies: 1
    Last Post: 07-18-2014, 12:15 PM
  3. This seems sill buy, how do I close an app!?
    By ShaneN. in forum Samsung Galaxy S5
    Last Post: 07-05-2014, 04:20 PM
  4. Can I not move the "apps" button?
    Last Post: 07-05-2014, 02:34 AM
  5. Galazy Gear v/s Android Wear app
    By lesir in forum Samsung Galaxy Gear
    Last Post: 07-05-2014, 02:20 AM
