Page 1 of 2 12 LastLast
Results 1 to 25 of 28
Like Tree1Likes
    mklabove's Avatar
    Posts
    Global Posts
    39 Global Posts
    Default Fleksy Update
    Fleksy has posted an update of their Messenger app, which seems much improved. I was one who only got the blank contacts screen, and I can now use the app. It opens to an Inbox screen, which makes it easy to reply to recent texts. You can see the names of your last nine texted contacts (why nine???), and it also shows the last 10 texts with those people.There is a search function, behind a Compose function (type in the name and hit search), so you don't have to scroll through all your contacts. It still seems to show all numbers for a contact, rather than just mobile numbers, and it doesn't identity which are mobile. But for me it's a huge improvement.
    Just FYI: My first attempt to simply update failed, so I unstalled Fleksy, rebooted phone and watch, and install went smoothly after that.
    Keith
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,673 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Fleksy Update
    Sometimes, it isn't fun to reinstall apps, but bad downloads happen. Thanks for the heads up.
  3. #3
    anon154738's Avatar
    Posts
    Global Posts
    182 Global Posts
    Carrier
    AOKP/ Franco Kernal
    Awesome update. I too had to Uninstall to update.
  4. #4
    Are all of you flesky fans using that app because you don't have good luck using S-voice to transcribe your voice to text? I hate using any kind of keyboard (I'm even getting sick of using a full sized keyboard at my PC) and prefer to use voice. I can speak a prodigious amount of text whereas if I had to type on a phone (or god forbid, my watch) I'd greatly reduce the amount of text I send out.
  5. #5
    Quote Originally Posted by 1812dave View Post
    Sometimes, dictating a text through voice isn't practical. You can't be discreet either which is the main advantage of texting. Besides, if you're just going to speak your conversation, wouldn't it be easier and more efficient to just dial the other person?
  6. #6
    anon154738's Avatar
    Posts
    Global Posts
    182 Global Posts
    Carrier
    AOKP/ Franco Kernal
    Quote Originally Posted by itinj6 View Post
    Completely agree. Discretion, and if I mis- speak one time, by the time I fix it I could've just text it out. I do use svoice sometimes though.
  7. #7
    I also had to uninstall and re install
    Posted via Android Central App on my Note 3
  8. #8
    there are very few times in my life when I HAVE to text immediately AND am in a situation where I can't dictate. There's nothing "life and death" about my texting so if I can't talk at the moment, IT CAN WAIT. I'm not a doctor or other pro who has to text in emergency situations.
  9. #9
    Where can I find this app?
  10. #10
    I've had no luck searching for any app using the search function in Samsung Apps( ie. Search for PayPal shows no results, but if I scroll through the apps in Financial, I see it there). In Utilities, under the ALL tab, I show it as number 17. Hope that helps!
  11. #11
    Quote Originally Posted by lizardchest View Post
    It's amazing how much difference there is from person to person when trying to find apps. I am one who has used the search function several times successfully.
    Also, I've got Fleksy as #18 under utilites.
  12. #12
    This update makes it 1000 times better. Still needs improvement like hopefully integration into the normal notifications app, and maybe a bit more memory so one can view more of the conversation and more than 9 or 10 conversations, but overall a MUCH needed improvement. Worth every penny...oh wait, it's free! Crazy!
  13. #13
    I only have 17 apps in utilities and number 17 is spritz mail app
    Sent from my SAMSUNG-SM-G870A using AC Forums mobile app
  14. #14
    Quote Originally Posted by Harry_Yambag View Post
    I show 127 apps under Utilities...but no Spritz mail app... There's been a lot of discussion about people having access to different apps, maybe based on phone model, carrier, physical location, or even height/marital status/hair color/who knows?!?!? But you should have more than 17 apps visible.
    As awful as it is to advise, you may have to uninstall/reset the Gear 2 and possibly your phone to get that **** to sync right...
  15. #15
    I was really hoping to NOT do that but if I'm missing over 100 apps, I really have no choice.
    EDIT: On AT&T, both phones are S5 Actives, in the US.
  16. #16
    Under new utilities I have a hundred thirty two apps. Under ALL I have a hundred thirty. Weird
    Sent from my SCH-I605 using AC Forums mobile app
  17. #17
    Is the Spritz app the speed reading one? Anybody try it yet?
  18. #18
    I'm looking at 135 under new utilities, and 132 under All.
    Also, I'm not seeing Spritz, either.
  19. #19
    What phones and carriers are you guys on?
  20. #20
    (Click on my avatar ) S3/US Cell/Midwest
  21. #21
    Thanks. You learn something new everyday.
    EDIT: Just deleted gear manager and reinstalled it...not only did I not gain more apps, I lost half the clock ones.
    Lesson learned.
  22. #22
    Glad a factory rest wasn't needed!!
    Hopefully you see more gain than loss with the app choices.
  23. #23
    I think you may have misread my post...I now have less apps available than I did before.
  24. #24
    I sure did! Reads much more positive with only one "not".
    Maybe uninstall Gear Manager, factory reset watch, then re-install GM. Not ideal, but WAY better than a phone reset if it works.
  25. #25
    Unfortunately, all I have left to do is the factory reset of the phone (which I'm prob not going to do). When I deleted Gear manager, it made me do a factory reset of the watch.
    Oh well. maybe the next update will fix this problem. I'm still loving the watch, just really wish I had all the apps available to make the experience even better.
  1. Replies: 7
    Last Post: 12-19-2014, 06:25 PM
  2. Galaxy S4 doesn't turn on after update. Help!
    Last Post: 09-04-2014, 01:46 AM
  3. Sony Xperia SP has no updates
    By emily96 in forum Ask a Question
    Last Post: 07-05-2014, 06:12 PM
  4. Phone dead after Software update
    By Judi Gowing in forum Samsung Galaxy S4
    Last Post: 07-05-2014, 12:59 AM
  5. Software updated and now phone is dead
    Last Post: 07-05-2014, 12:54 AM
