1. pacosal's Avatar
    Hi,
    I've just launched several Apps for gear 2 and I want to get feedback from users here because answering comments in Galaxy Apps Store is complicated.
    Notifications Clock is a Sun Clock with notifications support. You can read all description at Store.
    I'm currently developing a new version in order to fix some bugs that happen sometimes, but it's difficult to find them.
    Please, if you have installed the App, tell me here what do you thing and feedback about it.
    * It's a paid App
    Thanks
    07-11-2014 05:56 AM
  2. Turipz's Avatar
    Where is the app? Is it available for download? I've searched everywhere, and can't find it.
    07-12-2014 10:16 PM
  3. pacosal's Avatar
    Hi,
    the App is released at Samsung Galaxy Apps Store. You should see it at clocks category.
    I've just released a new version with some bugs fixed.
    Thanks
    07-13-2014 02:33 AM
  4. prubin's Avatar
    1. Needs 12 hour clock.
    2. Sometimes seems to use a lot of battery on the phone.
    07-13-2014 06:08 AM
  5. Turipz's Avatar
    Sorry, sir, but it's nowhere to be found. I looked again. Could you please provide a link to it? Something you have confirmed links to the downloadable app?
    Thank you
    07-13-2014 07:17 AM
  6. pacosal's Avatar
    1- 12 hours clock will be ready at new version.
    2- ummmh...will check it
    Thanks
    07-14-2014 12:50 AM
  7. pacosal's Avatar
    The store is in your device, there is no link to Apps out of the Store App.
    Look at the attached screenshot!
    07-14-2014 01:08 AM
  8. pacosal's Avatar
    New version released, now We have to wait a long week while Samsung certificates it.
    Thanks
    07-19-2014 03:22 AM
  9. gdanonym's Avatar
    Would be nice if the notifications can be dismissed from the watch.
    Or better if also the actions for the notifications can be activated from the watch on the phone. I'm using Tasker for creating notifications and most of the does actions, without user interface. So this would be ideal from the watch.
    07-21-2014 02:33 AM
  10. pacosal's Avatar
    Good idea, thanks for feedback.
    07-21-2014 02:55 AM
  11. pacosal's Avatar
    New version released!
    08-02-2014 01:48 AM
  12. Turipz's Avatar
    Well strike one more for not being able to find this app anywhere!
    While I understand that it is up to the retards at Samsung to control which app is available for which device, you developers need to stop thinking only as developers and more like business people - especially those of you who charge money for your apps, as these idiots are causing you to miss out on entire markets and thus hurt your income.
    I am sick and tired of the idiots at Samsung making such moronic decisions, not providing any reasonable explanations for them, and basically making my Samsung device less usable than the exact same phone from another part of the world.
    It's time these retards get some public flak for this crap they're putting their customers through.
    Harry_Yambag likes this.
    08-02-2014 08:35 AM
  13. prubin's Avatar
    Installed it. (Went to Samsung Apps in Gear manager and searched Notifications Clock.) But I cannot get it to work right. Shows only time, day and date. No weather. Flashing time works, but not much else.
    08-02-2014 10:46 AM
  14. pacosal's Avatar
    Hi and sorry for the delay.
    Please, run the App on your mobile device first and allow it to read your notifications. After that the App must work ok.
    I use it everyday with a Galaxy S4 and works ok.
    Thanks
    08-05-2014 08:04 AM
  15. gdanonym's Avatar
    The notifications are not optimized for the HTML viewing. If the message has a new line, it is not placed on the new line, but with a space . The new lines needs to be replaced with <br /> or if this is not readable "<"br /> (leave the " out).
    08-05-2014 09:22 AM
  16. Harry_Yambag's Avatar
    Preach on brother!
    I have an S5 Active and have almost NO apps available to me (37 apps total. Only 37 apps total and 21 of those are clocks!)
    08-05-2014 09:26 AM
  17. pacosal's Avatar
    Thanks for feedback!
    08-06-2014 12:47 AM
  18. gdanonym's Avatar
    How does the Tasker intent work. What will happen if tasker starts and stops with the commands?
    08-06-2014 02:05 AM
  19. pacosal's Avatar
    Hi,
    Tasker will enable or disable the App to send notifications to gear 2. The same than if you check or uncheck active at settings menu.
    Thanks
    08-06-2014 03:28 AM
  20. GMSchiller's Avatar
    Nice start...
    I've noticed a few small details...
    1. I can't get the battery to display.
    2. I can't seem to change temperature from Celsius to Fahrenheit
    3. there is no notification indication that shows on the main screen displaying how many unread notifications I have.
    Are these features in development still?
    09-20-2014 11:10 AM
  21. pacosal's Avatar
    If you tap on the hour this watch will show you the hour in big numbers and with a maximum bright to see the time in direct Sun Light.
    If you tap on the weather forecast, the forecast will be refresh.
    If you tap on the weekday you will access to the notifications screen.
    If you tap on the month receiving notifications will be enabled or disabled.
    To change from 24 hours clock mode to 12 hours clock mode tap on bottom right corner.
    To change from showing the battery level tap on bottom left corner.
    Tap on Top Left Icon to go to previous notification.
    Tap on Top Right Contact picture go to to next notification.
    Tap on Top Numbers to close this screen. x
    Scott Fandel likes this.
    09-21-2014 03:47 AM
  1. expert help needed for non standard Android question
    Last Post: 07-11-2014, 11:50 AM
  2. Replies: 1
    Last Post: 07-11-2014, 08:22 AM
