1. griswolds@earthlink.net's Avatar
    It seems after the latest updates, my Gear 2, when pressing home button to view time, the clock can be off by 5 or more minutes for a second or 2, then adjust to correct time. If my BT is off, I see the correct time when entering the password, then the watch face will come up, be wrong usually, then adjust to correct time a second or 2 later. This never happened prior to the software update. I've deleted the app, reset the watch and my phone, reloaded the app and still this happens. The stock clock "seems" OK, so I'm thinking this is a compatibility issue since the update. Anyone else seeing this? Thank you.
    07-13-2014 01:32 AM
  1. Galaxy Gear 2 clock slow to show correct time
    Last Post: 08-12-2014, 07:23 PM
  2. Cant use speech to text on my keyboard. It does not work.
    By AnimalMotherASF in forum HTC One M8
    Last Post: 07-13-2014, 02:28 AM
  3. Replies: 1
    Last Post: 07-13-2014, 01:09 AM
  4. Google Play Music - Saving to sd card for offline listening
    Last Post: 07-13-2014, 12:31 AM
  5. Update problem !
    Last Post: 07-13-2014, 12:24 AM
