1. Joebowler300's Avatar
    Is it possible to delete multiple/all the messages from my Gear 2? I mean either email or text messages. I am finding that I already have 100+ messages on my Gear 2, even though they are gone from my phone/inbox.
    Also, any way to delete from my phone when I delete from the Gear? as opposed to the "will delete on Gear only" message that I am getting.
    Just received my Gear yesterday, generally like it so far, just struggling to figure some things out. Have been reading the forums for about a week, and cannot find the answer to the above.
    07-15-2014 03:06 PM
  2. itinj6's Avatar
    When you open the notifications app on the watch, you will see a bunch of subsections I.e. email, Facebook, Hangouts, etc... Long press anyone of those (without actually opening it) and it will ask you if you want to delete xx messages from that subsection. Hit yes and it will remove that notification subsection type from your list.
    I don't think there is a way to remove items from your phone via the watch
    07-15-2014 07:15 PM
  3. 1812dave's Avatar
    all you have to do is drag down from the top on the screen that has the various notification types, and you will see "Delete All" in a gray bar. click that to delete ALL notifications.
    07-15-2014 07:28 PM
  4. Joebowler300's Avatar
    Think you meant drag up? I did that and found the "delete all" function, which is awesome.
    Really wish it would delete on my Note as well, but at least this is something! Appreciate the input and help!
    07-15-2014 10:03 PM
  5. 1812dave's Avatar
    Drag down to reveal bar at top.
    Sent from my SCH-I605 using AC Forums mobile app
    07-15-2014 10:58 PM
  6. Joebowler300's Avatar
    Weird. If I drag down it goes back one screen. Drag up I get the delete all function
    07-15-2014 11:00 PM
  7. lizardchest's Avatar
    If you swipe from the top of the screen, it goes back. If you drag down from somewhere in the middle of the screen it shows delete all.
    07-16-2014 05:59 AM
  8. 1812dave's Avatar
    Don't drag down from above the top of the screen. Drag down from the middle of the screen
    07-16-2014 08:27 AM
  9. gdanonym's Avatar
    I would be nice if the message auto deletes when it is read!
    I is dismissed on the phone, but still there on the watch.
    07-25-2014 05:08 AM
  10. 1812dave's Avatar
    Didn't you ever want to reference a message a second time?
    07-25-2014 08:59 AM
  11. gdanonym's Avatar
    These are only notifications of apps. The real messages can be read from the apps.
    In my phone if i click on the notification to read, it is also dismissed and gone.
    07-25-2014 09:14 AM
  12. 1812dave's Avatar
    When I go to Notifications on my watch, I can review a message (the first portion of it) as many times as I like. I don't HAVE to go to an app (unless I need to read more of the message which isn't that often, for the types of messages I receive).
    Secondly, I know that on the phone, if you click on a notification, it takes you to the app and then disappears. WHile that's fine and dandy it's also doing a lot more (which takes longer, and is more "complete" regarding the message contents). The beauty of the watch notifications is that they are right on your wrist, with the first portion ready to be read as many times as you choose. I really like the notifications on the watch (the primary reason I bought it, actually).
    07-25-2014 11:53 AM
  1. Tinder messages are NOT showing up, please HELP!?
    By Billy95Tech in forum General Help and How To
    Last Post: 07-17-2014, 08:00 AM
  2. Sync notifications across all devices
    By Aleik in forum Ask a Question
    Last Post: 07-16-2014, 05:54 PM
  3. HTC One X Multiple problems
    Last Post: 07-15-2014, 02:36 PM
  4. Quick delete of word when using stylus
    Last Post: 07-15-2014, 02:09 PM
  5. Unable to delete videos or photos in note 3
    Last Post: 07-15-2014, 01:43 PM
