1. Radon007's Avatar
    Hello,
    I haven't been able to find an answer and wanted to check here. Can you charge the Gear 2 on the cradle via a USB cable to your PC or Laptop?
    Thanks
    Mike
    07-15-2014 07:13 PM
  2. 1812dave's Avatar
    yes, but whenever charging ANYTHING via USB from a laptop, the charging rate will be lower than most other methods (other than my Camry, which has a dreadfully slow charging rate also )
    07-15-2014 07:30 PM
  3. JimSmith94's Avatar
    The charger that comes with the Gear 2 is pretty low amperage so it will charge almost as fast with USB from your computer.
    07-16-2014 01:11 AM
  4. Radon007's Avatar
    Thanks so much for your help!
    07-17-2014 09:27 PM
  5. qarliv's Avatar
    In principle you are right about the current, but the Gear charger supplies 4.75v and USB is around 5v. Does this difference posts a problem?
    09-07-2014 03:14 AM
  1. contact question
    By wetermommy in forum Samsung Galaxy S4
    Last Post: 11-03-2014, 07:49 PM
  2. LG G3 Micro SD card question
    By Peter_G24 in forum LG G3
    Last Post: 07-16-2014, 04:03 AM
  3. Battery not charging completely...
    Last Post: 07-15-2014, 05:59 PM
  4. HTC One M8 - Fully Charged Battery, Shows 1% all day
    Last Post: 07-15-2014, 05:10 PM
  5. Galaxy s5 s3 question
    Last Post: 07-15-2014, 04:35 PM
