1. prubin's Avatar
    I can connect my Verizon Note 3 to my Samsung Gear 2 but most of the functions from the watch to the phone -- schedule, emails, find my device, etc. -- do not work. It works the other way; I can change watch face from the phone, but I do not seem to be able to get the watch to talk to the phone. I have reset everything (watch, phone, bluetooth connection) and it still does not work. Is my watch broken, my phone broken,or something else? Anyone having the same problem?
    07-28-2014 07:06 AM
  2. lizardchest's Avatar
    Not sure what you mean about watch-to-phone emails and schedule... Are you trying to send an email via the watch? Set an appointment via the watch?
    There is currently no support for sending/replying to emails from the Gear 2. You should be able to use S Voice to set appointments. Find my Device should just work, so that is strange...
    Do you mean that you did a factory reset of watch and phone? I would try, in this order:
    1. Factory reset watch(Test if that fixes it)
    2. Uninstall/Re-install Gear Manager(Test)
    3. Factory reset phone(Test)
    07-28-2014 07:37 AM
  1. phone won't charge
    By Simon schof in forum HTC One M7
    Last Post: 07-30-2014, 05:06 AM
  2. Replies: 1
    Last Post: 07-28-2014, 12:56 PM
  3. Phone contacts
    Last Post: 07-28-2014, 07:06 AM
  4. Help connecting Samsung Galaxy via Bluetooth with Jabra Freeway
    By DanHarvard in forum Samsung Galaxy S5
    Last Post: 07-28-2014, 06:51 AM
