Results 1 to 2 of 2
    Default Weak Connection
    Often when my Verizon Note 3 is connected to my Gear 2, the connection does not fully work. I can get some stuff -- weather, mostly emails -- but more complex stuff does not connect. I have some news apps and just installed the new Wearable Widgets app, and some others, but they do not connect with the Note 3 even though both devices show that they are connected. I have wifi working on the phone but it does not seem to help.
  2. #2
    Default Re: Weak Connection
    I have the same problem. Turning off the Bluetooth on the watch not the phone then turn it back on again helps. I also deleted a ton of apps on the watch I wasn't using that helped as well. I notice most of the problems do arise when I use my cars Bluetooth that the apps do not work.
  1. Replies: 14
    Last Post: 11-03-2016, 03:27 PM
  2. Google Sync Error (can't connect to any Google Apps or account)
    By anon(8373095) in forum Google Play Store
    Last Post: 11-10-2014, 10:20 AM
  3. problem to connect hdmi to hdtv on galaxy tab 4 8.0
    Last Post: 09-08-2014, 03:18 AM
  4. connection between battery drain and motherboard.
    Last Post: 08-06-2014, 06:08 AM
  5. Samsung Tab 4 SM T530 cable/wireless HDTV connection
    Last Post: 08-06-2014, 03:36 AM
