1. anon154738's Avatar
    Can this be done? Using Tasker maybe?
    08-11-2014 11:56 AM
  2. 1812dave's Avatar
    You have to have a BT connection between phone and watch before ANY communication between them.
    08-11-2014 12:12 PM
  3. anon154738's Avatar
    Sorry I should've been more clear. I want to turn on my phone from the watch. Can this be done?
    08-11-2014 12:18 PM
  4. lizardchest's Avatar
    Maybe semantics here... I believe 1812dave, and most others, are assuming that you want your Gear 2 to "power up" your turned off phone. This cannot be done, as there is no connection to the phone if it is not powered on.
    Most(?) people define:
    --Turn on = Power up from an off state
    --Wake = wake from from standby state, usually just to lock screen
    --Wake/unlock or Unlock = Put phone on home-screen (Unlock does NOT always refer to having an security code, ie. swipe to unlock)
    Which are you asking about?
    I swear I got AppLauncher to unlock my phone a couple of times when I first got the app, but have been unable to replicate since the first day.
    08-11-2014 12:44 PM
  5. anon154738's Avatar
    Ok thanks. I'm totally with you on applauncher! I swear I was able to do this using applauncher and Tasker, but all my attempts have failed since.
    08-11-2014 01:17 PM
  6. NoFaQ's Avatar
    Pebble Locker works great, and can be configured to unlock your phone based on any connection to selected BT devices or WiFi connections.
    Edit: Link to Pebble Locker. https://play.google.com/store/apps/d...h.pebblelocker
    08-11-2014 02:04 PM
  7. lizardchest's Avatar
    The Gear Manager already gives the option to activate/deactivate pattern lock. Pebble Locker may give more options.
    It seems the OP was looking to either turn on from a powered off state, or wake and unlock via an app on the watch. Pebble Locker and the built in one in GM only change whether or not you need to enter some sort password after one physically wakes the phone. AFAIK, neither will wake and unlock via connection, and neither will turn the phone on from an off state.
    08-11-2014 03:30 PM
  8. NoFaQ's Avatar
    Misunderstood. Ah, well I was never able to get that to work from the GM, and I didn't realize I was a minority.
    I've not seen anything that can wake and unlock to a homescreen, just from a function within an app on the watch itself; email, IM, etc.
    08-11-2014 03:51 PM
  9. lizardchest's Avatar
    My GM lock works well. Slight delay, but not a big deal. And you never know, I could be the minority who it works for...
    I'm just glad someone else was able to wake/unlock at some point with AppLauncher. I was positive I could at one point, then started doubting myself......
    I even emailed the dev, with no response...
    08-11-2014 04:40 PM
  1. Replies: 2
    Last Post: 08-22-2015, 11:28 AM
  2. Game saved on SD card is not showing up on new phone.
    Last Post: 08-14-2014, 11:52 AM
  3. How durable is the on/off button
    By Tiriyon in forum HTC One M8
    Last Post: 08-12-2014, 12:48 PM
  4. How to get Unlimited T-mobile Hotspot on A LG G3
    By seanjohn2032 in forum Ask a Question
    Last Post: 08-11-2014, 12:03 PM
  5. Lock phone without waiting for scheduled time period.
    By Jawnboi in forum Ask a Question
    Last Post: 08-11-2014, 11:41 AM
