Results 1 to 5 of 5
    zaydabarber's Avatar
    Posts
    Global Posts
    290 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default path for the gear 2 I don't see it in app store
    Gear 2
    at&t galaxy note 3, tab 2 10.1
  2. #2
    NoFaQ's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: path for the gear 2 I don't see it in app store
    Quote Originally Posted by zaydabarber View Post
    Gear 2
    Are you talking about finding the apps for the Gear 2?
    You have to go to Samsung Apps through the Gear Manager, and not through the standard Samsung Apps.
    Posts
    Global Posts
    290 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes I look I dont see it for the gear 2
  4. #4
    JimSmith94's Avatar
    Posts
    Global Posts
    740 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Freeza'sfre3 KitKat 4.4.2
    Have you installed Gear Manager from the main Samsung Apps? Then you can go into Gear Manager and select Samsung Apps for the Gear 2. They made it as complicated as they could.
  5. #5
    srsgonu's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There's an easy way. Touch the notification (from drop down) that you are connected to Gear 2 and it launches Gear manager.
  1. Sprint Getting Rid Of The Framily Plans
    By Yung_Dilla in forum Sprint
    Last Post: 08-21-2014, 06:40 PM
