1. zaydabarber's Avatar
    Gear 2
    at&t galaxy note 3, tab 2 10.1
    08-15-2014 01:30 AM
  2. NoFaQ's Avatar
    Gear 2
    Are you talking about finding the apps for the Gear 2?
    You have to go to Samsung Apps through the Gear Manager, and not through the standard Samsung Apps.
    08-15-2014 09:00 AM
  3. zaydabarber's Avatar
    Yes I look I dont see it for the gear 2
    08-16-2014 12:08 AM
  4. JimSmith94's Avatar
    Have you installed Gear Manager from the main Samsung Apps? Then you can go into Gear Manager and select Samsung Apps for the Gear 2. They made it as complicated as they could.
    08-16-2014 12:44 AM
  5. srsgonu's Avatar
    There's an easy way. Touch the notification (from drop down) that you are connected to Gear 2 and it launches Gear manager.
    08-18-2014 01:25 AM
  1. Sprint Getting Rid Of The Framily Plans
    By Yung_Dilla in forum Sprint
    Last Post: 08-21-2014, 05:40 PM
