I use voice to text on my Gear 2 a lot. I recently used some profanity and it kept the first letter and put the rest as * (example - s***). Anybody know how I can fix it so it doesn't do it again?
Go to your app drawer, select S voice, then select settings and you should see option to hide offensive words with a check box. Sounds like your box is checked.
