I posted this in another post, but should be an upfront discussion as it happens so often it is becoming for a need to get rid myself of the Neo Gear smartwatch and seriously look into the Android Wear smartwatches....
I'm going to be doing some serious inquiry in research to see if those smartwatches will fulfil my needs, The worst thing of which I like the Tizen smartwatches is for the Battery Life of which I average 3 to 4 days and these Android Wear smartwatches are severely lacking for in only 1 day.
How are the rest of you relating with this constant problem?...
I originally had a Galaxy Note 2 with my Neo Gear smartwatch to then upgrade to a Galaxy Note 4 of which I was fine until the Samsung Updates started the Domino effect of problems once again to contend with.....
