500 calorie goal limitation
Hi,
Does anyone know why is there a 500 calorie goal limit on the gear 2?
When you go to exercise-running-goal-calorie-manual you can't set it to more then 500 cals.
Which is ridicules do to the fact that you can definitely set up a goal on the s - health on the phone for more then 500 cals.
What is the reason for that limitation? and is there a way to overcome it?
Maybe set up the running goal on the phone and then transferring it to the gear?
I would appreciate any response!
Thanks.
Hi,
Thanks.
