1. doohsun's Avatar
    I saw in the manual that the gear fit allows you to setup up a couple of emergency number for some reason there's no option on my gear fit anyone else having the same issue?
    04-24-2014 12:59 PM
  2. pughmat's Avatar
    I believe you configure this within the Gear Fit Manager App. Manage Primary Contacts. Once those are set up, you are then able to press the power button three times in a row to send a help request. If you are not using a Galaxy S5 though with S Health 3.1, this option may not be available.
    04-24-2014 04:55 PM
  3. schultz84's Avatar
    So if you own an S4 you can't get the latest version of S Health. WHY?
    04-24-2014 05:30 PM
  4. doohsun's Avatar
    Ya i'm beginning to to think this might have to do with me not having an s5 lol
    04-25-2014 07:38 AM
  5. pughmat's Avatar
    Yes. S Health 3.1 is currently available for the S5 only as far as I know. My wife also has a Gear Fit with an S4 and we have different versions of S Health. In fact, she must use an App called Fitness with Gear, which I don't need on my S5. At the bottom of a Samsung support website, it mentions that it some features are only available for the S5 with an update to other devices "coming soon" which we all know could be within a week or a year.
    04-25-2014 09:12 AM
  1. Replies: 1
    Last Post: 04-24-2014, 01:06 PM
  2. Change backgroudn color of settings menu
    By meashishnd in forum Samsung Galaxy S3
    Last Post: 04-24-2014, 12:46 PM
  3. Can't undo setting that switches between wifi and network
    By rj5k in forum Verizon Galaxy S III
    Last Post: 04-24-2014, 11:58 AM
  4. Setting a downloaded ringtone as a text tone?
    By Victor Franklin in forum Wallpapers, Ringtones, and Themes
    Last Post: 04-24-2014, 11:24 AM
