Results 1 to 5 of 5
    JimCurr's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Gear Fit apps
    Anyone know a way or an app to get a "things to do list" on the gear fit (not just the outstanding calendar appointments? i.e. a nagging list
  2. #2
    skraam's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Gear Fit apps
    You can download "Gear fit share" from the market., Then go to your To do list, select all and share via Geat fit share app. That list will then be on your fit.
  3. #3
    StevenJ_AK's Avatar
    Posts
    Global Posts
    188 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The developer Do Minh Duc just released three new apps for the gear fit. They are in the play store but one of them is what you're looking for
    Sent from my SAMSUNG-SM-G900A using AC Forums mobile app
  4. #4
    GeekyMom's Avatar
    Posts
    Global Posts
    1,952 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm looking for a battery monitor or display app, any suggestions? Thanks
  5. #5
    Kay Ronny Dahl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    How can I get to a spesific app from the "App Connect" when I double-tap on the home button on my Gear Fit?
    Now I have to double-tap that gets me to the App Connect-folder and then press the preferred app (in my example: Launcher).
  1. Replies: 28
    Last Post: 06-02-2016, 08:40 PM
  2. Has T-Mobile dumped the "My Account" app for Android?
    By Dayvidpriddy in forum T-Mobile
    Last Post: 05-21-2014, 06:55 AM
  3. Gear Neo...
    By SMD in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-16-2014, 06:16 PM
  4. Replies: 1
    Last Post: 05-16-2014, 11:40 AM
  5. Best Game Apps for KitKat
    By LumiaManiac in forum Android 4.4 KitKat
    Last Post: 05-16-2014, 12:12 AM
