1. PlanetPluto7's Avatar
    Using Textra or whatever; no text messages on my Fit. Anyone can help?
    07-25-2014 11:04 AM
  2. Prince_Poppycock's Avatar
    I'm using Textra with the Gear Fit and it does work.
    Make sure in the Gear Fit Manager app under notifications that you have the Textra app check marked and the stock messaging app unchecked.
    Hopefully that will work for you!
    Sent from my Note 3
    07-28-2014 09:59 AM
  3. MomoMilky's Avatar
    How did you get Textra to work with GearFit? My stock messenger app keeps crashing and lagging, so I want to link Textra to Gearfit instead.
    01-12-2015 04:59 PM
  4. Prince_Poppycock's Avatar
    All I did was go into the Gear Fit Manager app and under Notifications scroll down and check the box next to Textra in the list of apps. You also need to uncheck the stock messaging app. It's worked flawlessly for me using the Textra app.
    Sent from my Note 4
    pantlesspenguin likes this.
    01-13-2015 09:03 AM
  5. MomoMilky's Avatar
    Thank you, I will try to see if it works for me. Stock messaging app is driving me crazy!
    01-13-2015 10:31 AM
  6. Prince_Poppycock's Avatar
    No problem! Glad I could help!
    Sent from my Note 4
    01-13-2015 12:59 PM
  7. MomoMilky's Avatar
    Unfortunately Textra app did not show up in my Gearfit manager
    02-02-2015 05:22 PM
  8. Prince_Poppycock's Avatar
    That's strange. All my apps show up under notifications in the Gear Fit Manager. I do know that you can only have 10 apps in use on the Gear Fit at a time. Could that be the problem?
    Sent from my Note 4
    02-03-2015 06:29 AM
  9. MomoMilky's Avatar
    There's only a few apps shown in the notification area of the gearfit manager. I will take a screenshot when I get a chance.
    Was really hoping it would work too!
    02-04-2015 11:51 AM
  10. Prince_Poppycock's Avatar
    Here are a couple of screen shots from my gear fit manager.
    Sent from my Note 4
    02-04-2015 01:37 PM
  11. pantlesspenguin's Avatar
    Aw man! I saw your screenshot and I was excited to set up emergency alerts to come to my Fit, but I don't have the option .
    03-16-2015 12:10 PM
  12. Prince_Poppycock's Avatar
    That sucks, it must be carrier based. I'm on Verizon.
    Sent from my Note 4
    03-18-2015 11:19 AM
  13. pantlesspenguin's Avatar
    Sent from my Note 4
    That's probably it. I'm on T-Mo.
    03-18-2015 12:30 PM
  14. mountainbikermark's Avatar
    Sent from my Note 4
    I don't have it on AT&T either.
    03-19-2015 07:23 AM
  1. Replies: 1
    Last Post: 07-26-2014, 02:16 AM
  2. Time no longer showing on screen without swiping
    Last Post: 07-25-2014, 05:22 PM
  3. No sound on notification
    Last Post: 07-25-2014, 04:02 PM
  4. Scratch on the Screen
    By laurenwm in forum HTC One M8
    Last Post: 07-25-2014, 10:58 AM
  5. Irritating Error Message on my Samsung S5
    Last Post: 07-25-2014, 10:39 AM
