I recently got a Gear Fit for my birthday and went thru Gear Fit store to find apps. Google Fit was in the Gear Fit store, so I assumed it would work with the Gear Fit, but I can't see where it would be added onto the Gear Fit (whether it's thru App Connect or some other method). Does anyone use Google Fit? If so, have you linked your Gear Fit to it or know how?
-using Samsung Galaxy Note 2
