Results 1 to 2 of 2
    Default Gear Fit updated with option to enable vertical display orientation
    The Gear Fit is one of the prettiest and most stylish fitness tracker you will ever come across, with a beautiful AMOLED display the window into its functions and features. However, the Gear Fit had one tiny limitation that was irking some users: all info on the display would be displayed only horizontally, making it a bit awkward in use when the device is on your wrist. Thankfully, that limitation might not remain on the Gear Fit for long, as Samsung has apparently updated the tracked with an option to enable vertical display orientation that should make general usage quite a bit more convenient.
    The existence of this feature has been confirmed by a Gear Fit on display in an official Samsung store in South Korea. Its unclear when the update will roll out to the Gear Fit in other regions, though it should be soon after the device goes up for sale globally on April 11, along with the Gear 2 and Galaxy S5.
    Photos and Source: Samsung Gear Fit updated with option to enable vertical display orientation | SamMobile
    Sent from my SM-P600 using AC Forums mobile app
  2. #2
    Default Re: Gear Fit updated with option to enable vertical display orientation
  1. Replies: 16
    Last Post: 08-19-2015, 10:01 AM
  2. Man smashes Galaxy S5 with hammer, Galaxy S5 takes revenge
    By smooth4lyfe in forum Samsung Galaxy S5
    Last Post: 04-11-2014, 09:44 PM
  3. Saving Wikipedia Offline to the computer before factory reset
    By BhargavJ in forum Barnes & Noble Nook HD / HD+
    Last Post: 04-10-2014, 07:55 AM
  4. How to Separate files in music library?
    By wellplayed in forum General Help and How To
    Last Post: 04-08-2014, 10:38 PM
  5. lg g2 kit kat 4.4 update; no custom led
    By blackns in forum T-Mobile LG G2
    Last Post: 04-08-2014, 08:39 PM
