07-25-2014 12:04 PM
Like Tree1Likes
  • 1 Post By Prince_Poppycock
    Default No SMS on Fit
    Using Textra or whatever; no text messages on my Fit. Anyone can help?
  2. #2
    Default Re: No SMS on Fit
    I'm using Textra with the Gear Fit and it does work.
    Make sure in the Gear Fit Manager app under notifications that you have the Textra app check marked and the stock messaging app unchecked.
    Hopefully that will work for you!
    Sent from my Note 3
  3. #3
    How did you get Textra to work with GearFit? My stock messenger app keeps crashing and lagging, so I want to link Textra to Gearfit instead.
  4. #4
    All I did was go into the Gear Fit Manager app and under Notifications scroll down and check the box next to Textra in the list of apps. You also need to uncheck the stock messaging app. It's worked flawlessly for me using the Textra app.
    Sent from my Note 4
    pantlesspenguin likes this.
  5. #5
    Thank you, I will try to see if it works for me. Stock messaging app is driving me crazy!
  6. #6
    No problem! Glad I could help!
    Sent from my Note 4
  7. #7
    Unfortunately Textra app did not show up in my Gearfit manager
  8. #8
    That's strange. All my apps show up under notifications in the Gear Fit Manager. I do know that you can only have 10 apps in use on the Gear Fit at a time. Could that be the problem?
    Sent from my Note 4
  9. #9
    There's only a few apps shown in the notification area of the gearfit manager. I will take a screenshot when I get a chance.
    Was really hoping it would work too!
  10. #10
    Quote Originally Posted by MomoMilky View Post
    Here are a couple of screen shots from my gear fit manager.
    Sent from my Note 4
  11. #11
    Aw man! I saw your screenshot and I was excited to set up emergency alerts to come to my Fit, but I don't have the option .
  12. #12
    Quote Originally Posted by pantlesspenguin View Post
    That sucks, it must be carrier based. I'm on Verizon.
    Sent from my Note 4
  13. #13
    Quote Originally Posted by Prince_Poppycock View Post
    Sent from my Note 4
    That's probably it. I'm on T-Mo.
  14. #14
    Sent from my Note 4
    I don't have it on AT&T either.
  1. Replies: 1
    Last Post: 07-26-2014, 03:16 AM
  2. Time no longer showing on screen without swiping
    Last Post: 07-25-2014, 06:22 PM
  3. No sound on notification
    Last Post: 07-25-2014, 05:02 PM
  4. Scratch on the Screen
    By laurenwm in forum HTC One M8
    Last Post: 07-25-2014, 11:58 AM
  5. Irritating Error Message on my Samsung S5
    Last Post: 07-25-2014, 11:39 AM
