Results 1 to 8 of 8
    AzD
    AzD is offline
    AzD's Avatar
    Posts
    Global Posts
    221 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Random thoughts on Gear Live
    The band - I don't find it to be all that bad as people are making out. It is less fiddly to put on than my fitbit flex. Not that hard to clasp, really, just feel the holes and push in and it latches. As for style, that is just individual taste but this is kind of a geeky gadget so I am not at all put off by its looks. Nice that you can change them, but for me, I'll keep the stock one.
    The screen - I don't find it that bad in the sun. Using the white clock face, I could easily see what time it was in full sun. Yeah, I couldn't see it very well looking at an angle, but looking straight on, it wasn't as hard to see as I thought it would be after reading the early reviews. I was prepared for a complete black out, but, nope; it is no better or worse than any smartphone I have used, IMO.
    The charging base is kind of fiddly but those reports of it breaking - I can't see it, if you take a bit of care with it. Maybe I will be proven wrong on that point. They could stand to improve the design and make it simpler in future models.
    Someone posted about the lack of auto capitalization when dictating a text message - I agree, that needs to be fixed. That is not specific to the Gear Live though, I assume that is an Android Wear software thing.
    Another post was about the need to be able to buy additional charger bases. I agree with that as well, but I fear if they make them available, they will be like $35 or more, based on past history.
    So far I am really liking the watch. Taken for what it is - a complement to a smartphone - it is pretty neat. I hope to see some interesting advancement of the technology.
  2. #2
    Chimpware's Avatar
    Posts
    Global Posts
    30 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Random thoughts on Gear Live
    In agreement completely with all your comments.
    I actually like the band, not the easiest to get on, but seems secure and is really comfortable.
    One thing I would add is that it is a bit confusing to get some apps working if you are not familiar with how they interact with the watch. Great example is Evernote where you can say "OK Google... Start Evernote" and then get a list of options on the watch. Other apps are similar, but you can also use the same command for non-wear apps and it launches the app on the phone so it is a bit confusing if you don't have a clear understanding of which apps are wear apps and which are not, and which require a companion app, and which just provide functionality within the app on the phone.
  3. #3
    indianajonze's Avatar
    Posts
    Global Posts
    518 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Chimpware View Post
    meanwhile, i try "ok google start evernote" on the watch and it instantly opens it on the phone...
  4. #4
    clrk9000's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The band looks really nice and is very comfortable BUT IT IS NOT SECURE. I dropped my Gear Live while I was using it and broke the screen. I suggest you replace the band the soonest you can.
  5. #5
    dsignori's Avatar
    Posts
    Global Posts
    1,706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The band works fine for me. The clasp is odd, but works fine and stays on perfectly.
    The charger, well the charger is simply the worst designed charger on the planet. I can't tell you how much of a PITA it is for me. There has to be a better way.
    There should have been more watch faces to choose from at launch too. Overall, It's OK for me, I don't love it, don't hate it. I will probably get the Moto 360 though, perhaps just for frustration free charging (if that ends up being true for the 360).
  6. #6
    bigga85's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My gear live is killing my battery on my moto x
  7. #7
    virgocalifornia's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Alot of your observations are spot on for me. I knew about many of these pros/cons before switching over from Neo 2. I do miss the sound for reminders and messages. That's an opportunity for Samsung to improve because the vibration is weak and short.
  8. #8
    ahershey's Avatar
    Posts
    Global Posts
    61 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cradle is poor design. I had mine for 4 months and then the very small post that holds it in place wore off (did not break, just wore off). Samsung refuses to replace without sending everything back to them. This was after 5 calls, 4 times saying that it was in the mail and would be there in 5 business days.
  1. Person shortcut on home screen opens wrong contact
    Last Post: 09-04-2014, 02:00 AM
  2. Any Solutions to managing files on SD cards on Kit Kat yet?
    By OceanView in forum Samsung Galaxy Note 10.1
    Last Post: 07-26-2014, 12:16 PM
  3. I just purchased an HTC 720e ONE X and it will not turn on.
    Last Post: 07-10-2014, 12:24 PM
  4. Galaxy S3 won't power on
    By kirbyg53 in forum Ask a Question
    Last Post: 07-09-2014, 11:20 PM
  5. setting up MS Exchange on LG Motion ICS 4.0.4
    Last Post: 07-09-2014, 09:38 PM
