Results 1 to 8 of 8
    Devhux's Avatar
    Posts
    Global Posts
    720 Global Posts
    Default Settings shortcut
    I'm not sure if this has been mentioned, but the Gear Live has a quick way to get to the Settings screen. Simply hold down the side button for a couple of seconds until you feel a light vibration. You'll be taken immediately to settings.
    This is useful if you need to quickly adjust brightness levels (for example, stepping outdoors).
  2. #2
    Default Re: Settings shortcut
    Thanks for that tidbit - very useful to me.
  3. #3
    bujin's Avatar
    Posts
    Global Posts
    143 Global Posts
    Yes, that made a huge difference to me. Getting to apps doesn't really bother me, since it's pretty easy to get to Fit, but getting to brightness was a hassle.
  4. #4
    Chimpware's Avatar
    Posts
    Global Posts
    30 Global Posts
    May want to check out Wear Mini Launcher:
    https://play.google.com/store/apps/d...arminilauncher
    Gives you direct access to Brightness as well as the apps on your Android Wear device. Works really well.
    T-Rob likes this.
  5. #5
    Is there a category for these stabdalone apps? How would an average user find this besides typing in wear within the search area? Thanks!
    Devhux's Avatar
    Posts
    Global Posts
    720 Global Posts
    I posted this very shortly before Wear Mini Launcher added the brightness toggle (darn developers trying to steal my thunder!)
    I ended up discovering the settings shortcut by accident.
  7. #7
    mrmnlando's Avatar
    Posts
    Global Posts
    45 Global Posts
    I actually downloaded an app called Wear Store which will show all the apps specific to android wear. Now I'm not sure how the app searches for these apps in the store, but it seems to represent about 140 apps currently out there and continues to update with new apps every day. It will like you to the play store if you're ready to download the app. I check here every few hours actually, waiting for something revolutionary! :0
  8. #8
    Quote Originally Posted by mrmnlando View Post
    Lol. Thanks! I've now been doing the same.
  1. Let's see some pics or screen shots of how you have your Tab S set up!!
    By SAMmarked1 in forum Samsung Galaxy Tab S 10.5
    Last Post: 10-08-2014, 12:41 AM
  2. How can I set up an AT&T Note 2 for T-mobile?
    By AC Question in forum Samsung Galaxy Note 2
    Last Post: 07-14-2014, 12:38 AM
  3. ATT rooted S3 unable to open settings page after recent firmware update
    By fstone88 in forum AT&T Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 07-13-2014, 07:05 PM
  4. Show off your Tab S post pics or screen shots of your set up!!
    By SAMmarked1 in forum Samsung Galaxy Tab S 8.4
    Last Post: 07-13-2014, 12:06 PM
  5. Apps and Setting missing!
    By AlwaysSmile in forum LG G3
    Last Post: 07-13-2014, 10:37 AM
