1. jlo3378's Avatar
    Is it possible to control the volume of your media player with this watch? I've searched but can't find an answer. Trying to decide what I want to get.
    Thanks in advance!
    Sent from my VS985 4G using Tapatalk
    07-22-2014 11:36 PM
  2. mxrider821's Avatar
    There is an app that will do what you want plus more, but before making a new thread try searching the play store for apps. There's over 250 apps already out for the gear live and the list continues to grow daily. You can download the music app from the play store. It's called "wear music controller" now you can enjoy your music from your watch!
    08-02-2014 11:29 PM
  3. Mikest's Avatar
    If you're running Wear Mini Launcher it now has a sliding scale for media volue or theres several apps in the play store not. I was using one called wear volume on my G Watch until they updated Wear Mini Launcher to include a volume slider. The apps still a bit annoying to get to as volume should be quick and easy to access as a native feature of the watch but it is what it is.
    jlo3378 likes this.
    08-09-2014 08:12 PM
  1. In call volume, is yours very low...
    By stephanie85 in forum Samsung Galaxy Note 3
    Last Post: 07-22-2014, 08:59 PM
  2. Replies: 0
    Last Post: 07-22-2014, 03:19 PM
  3. Low volume speakers after S5 is dropped in melted chocolate
    By jlehrer100 in forum Samsung Galaxy S5
    Last Post: 07-21-2014, 03:37 PM
  4. S5 volume - volumes disappear
    By stevec60 in forum Samsung Galaxy S5
    Last Post: 07-21-2014, 02:23 PM
  5. No Volume when changing from normal mode to vibrating.
    By Kenneth Jansen in forum Samsung Galaxy S5
    Last Post: 07-21-2014, 09:53 AM
