Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By mountainbikermark
    Default Heart rate monitor during exercise?
    I'm intrigued by the Gear S. Does anyone know yet whether the heart rate monitor works well during exercise, unlike the Gear Fit?
  2. #2
    Default Re: Heart rate monitor during exercise?
    i just got the gear s sat. but went for a ride and used Endomondo and it gave me a heartrate monitor readout which is consistent with whose I've seen with other apps.
  3. #3
    Yes, it is not as good a HR monitor as your typical chest strap, and frankly there are better optical monitors out there, but they tend to be in dedicated sports watches.
    The S does a reasonable job. However, the exercise apps do seem to be some of the biggest battery drains. If you really want a good exercise watch I'd be more likely to go with something in that space. Personally on rides I have the S on my wrist for communication, but use the Garmin mounted on the bike for tracking.
    My wife sometimes caries the S with her on runs, but the Garmin is on the wrist, and the s in a pouch just in case.
  4. #4
    My Fit worked fine, about as accurate as my Nike hrm watch. S is just as good for me.
    If you find inaccurate readings you can turn the watch (Fit or S) so the face is on the underside of your wrist.
    sirCLD likes this.
  5. #5
    I use mine during bball and it works great as long as it make it a little tighter than i normally wear it
  1. Replies: 3
    Last Post: 09-28-2014, 05:07 AM
  2. Galaxy S5 Compatible Heart Rate Monitor w/ Strap?
    By DRILLINDK in forum Samsung Galaxy S5 Accessories
    Last Post: 09-24-2014, 11:30 PM
  3. Lound message notification during phone call
    Last Post: 09-02-2014, 07:02 PM
  4. how to use the alphabets while dialing or during a call
    Last Post: 09-02-2014, 03:38 AM
  5. Screen flashing on and off during phone use
    Last Post: 09-01-2014, 12:13 PM
